Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
How to Read (save) RAID 1 disc without RAID controller
RaidNewbie1951
I have an MSI Pro z790-p wifi mobo.  I installed a Raid 1 pair of Seagate barracuda discs. (2TB ea).
My SSD system drive died and I am struggling to get the Raid controllers set up on a clean install of Windows 11 on a new SSD. I cannot lose the data.
I want to know how to read / mount 1 of my Seagate drives for read only so that I can back up the data to another drive (5TB portable storage disc.).
(Once done then I can try to get the Raid reinstalled but some of that data is more important than I had realized and mustn't lose it.)
I read something about the MBR being larger on the RAID disc than for a normal disc and that it is possible to exclude that data band when mounting the drive so that it can be read.  How do I do that please.
Many Thanks for your help.
RobbieR_Intel
Hello RaidNewbie1951,
Thank you for reaching out. I understand that you would like to know how to read/save your Raid 1 disc without RAID Controller.
Since you have mentioned that you were using RAID 1, please answer the following questions:
  • What are you currently using? Intel RST or a another RAID Controller utility?
  • Was the operating system installed on the current RAID setup?
  • What is the reason why you removed the RAID setup from your Motherboard?
  • What is the current status of your RAID setup? Does it still show as RAID volume, or are the drives operating as standalone disks?
I look forward to your response!
Robbie R.
RobbieR_Intel
Robbie R.
RobbieR_Intel
Robbie R.
