Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
IRST 11.7 interface crashing.
MSmit17
I updated my asus mobo bios and im running irst 11.2, the bios says supports 11.2 all this under windows 7 32 bits.
Today i installed windows 7 64 bits now i wonder if i could be able to run irst 11,7?
somebody knows if the bios has to match the irst version? I tried to run 11.7 under windows 7 32 bits and the interface crashed all the time.
DZand
Valued Contributor I
The Intel RST drivers v11.2 and v11.7 are totally different regarding their structure and their functionality.
All "conservative" Intel AHCI and RAID drivers from v8.x.x.xxxx until v11.2.x.xxxx are using just 1 driver (= SYS file) named iaStor.sys, whereas all newer Intel SATA drivers from v11.5 up to v12.5 are working with an AHCI/RAID driver named iaStorA.sys and an additional SCSCI filter driver named iaStorF.sys.
Since the development of the new RST drivers and their accompanied RST Console software is rather new, there were some earlier versions in the past with stability problems.
If your mainboard has an actual Intel chipset (5 Series or newer), I recommend to use the newest official RST drivers v12.0.0.1082 resp. the package v12.0.0.1083. According to my knowledge both are rock stable.
Advice: Before you install any new Intel RST driverpack, you should uninstall the previously used IRST software and do a reboot. This way you can prevent a lot of unnecessary problems.
Now to your question regarding the relationship between the BIOS and the SATA drivers: There is one, because the version of the Intel RAID ROM resp. EFI "SataDriver" module, which both are part of the BIOS, should match with the version of the in use IRST drivers to get the best results. Most important is this for RAID systems, where the user wants to get Win7 or Win8 installed in UEFI mode. In this case the OS Setup may not accept any of the "conservative" Intel RAID drivers using the iaStor.sys.
MSmit17
Thanks for the info Fernando you know a lot congrats.
Well i have an asus p8z68 pro /gen 3 mobo with an i7 2600 2gen processor, i have the lastest asus bios which says is compatible with ISRT 11.2 released last year.
I dont know if the new IRST like 12.0 would work on my machine sadly right now intel download center is not online.
Do you think it will work? where are those 12 drivers cause intel download center only shows these being the 11.7 the latest:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Software+Products&ProductLine=Chipset+Software&ProductProduct=Intel%C2%AE+Rapid+Storage+Technology+%28Intel%C2%AE+RST%29&ProdId=2101&LineId=1090&FamilyId=42 Download Center
DZand
Yes, I think, that they will work for your system.
You will find these v12.0 drivers dated 01/02/2013 at Intel's Download Center, if you search for "12.0.0.1083". They can be used with with AHCI and RAID systems as well.
If you should not been satisfied with these new RST driver generation using an additional SCSI driver, I recommend to reinstall the last "conventional" Intel RST driver v11.2.0.1006. Don't forget to uninstall the currently running RST software before you are going to install another RST driverpack.
MSmit17
Hi Fernando
It didnt work, same assertion error:
Only 11.2 is still stable for MANY of us. rolling back..........
DZand
@ Antonio:
Your negative results with the v12.0.0.1082 drivers really surprised me, because I have seen a lot of reports from Z68 chipset users, who were very satisfied with them.
Nevertheless your decision is understandable: Stick with the "conventional" RST driver v11.2.0.1006, which comes without the additional SCSI filter driver.
MSmit17
Well this problem is pretty old:
and yes i've heard about some people not having problem but there are others like me who have.
IMO the Intel software is still buggy.
DZand
/thread/31737 IRST 11.6 is bugged!
The problems with the RST v11.6 software are wellknown, but I thought, that Intel had solved them with the RST v12 series.
By the way: Have you ever tried to install just the RST drivers without the software?
That is what I am doing.
MSmit17
sure i believe i tried with version 11.7 same problem.
J280
I have also had this problem since installing Windows 8 (64 Bit)
I have tried IRST versions 11.5.4.1001, 11.6.0.1030, 11.7.0.1013 and 12.0.0.1083 and they have each failed with an assertion error.
The application then returns an "Unknown Error" resulting in the IRST service failing to start.
Note in the screen capture below that the "Accelerate" button is missing.
I understand that the "Accelerate" button may not show if the SSD to be used for caching is not installed, but in my case it is and can be seen by right clicking "Computer" then "Manage" then "Disk Management".
It is shown as 59.63 GB of unallocated space, which I understand is exactly as it should be.
My motherboard is a Gigabyte GA-Z77-D3H with the latest Bios, if that information is of any help.
Any advice would be greatly appreciated.
Thanks in advance.
Jim
On any Intel RST versions higher than 11.2 (on 11.5, 11.6, 11.7, 12.5) in case of start of the utility of a configuration the error is constant:
On the Intel RST 12.0 BSOD version in case of computer start:
BSOD 0x0000001E (0x0000000000000000, 0x0000000000000000, 0x0000000000000000, 0x0000000000000000)
I checked with Intel RAID OROM 10.5, 11.2 and 12.5.
http://forums.overclockers.ru/viewtopic.php?p=9880576# p9880576 http://forums.overclockers.ru/viewtopic.php?p=9880576# p9880576
I ask for help.
Win 7 SP1 x64 Proffessional + full hot-fix
MB ASUS P8P67 PRO Rev:3.0 BIOS 3602 Intel RST OROM v12.5.0.1815 TRIM mod
Video ASUS GTX560 Ti DirectCU II
Ram 8192MBx2 1600MHz
SB X-Fi Xtreme Gamer
SSD PX-128M5S
RAID0 2x500Gb WD RE4 WD5003ABYX
HDD Seagate ST3500418AS 500Gb
BD-RW PIONEER BDR-207D
DVD-RW/+RW LG GH22NS50
DArce
Valued Contributor III
Could you please provide your system report generated by Intel(R) Rapid Storage Technology?
http://www.intel.com/support/chipsets/imsm/sb/CS-023487.htm http://www.intel.com/support/chipsets/imsm/sb/CS-023487.htm
And also the dxdiag report (Start menu, type dxdiag, click on save all information)
MSmit17
No i cant (im not gonna install the sofware all over again in order to generate a report that Intel should be already be aware cause im not the only one), but thanks for trying to help.
What to save the system report it is necessary to launch Intel Rapid Storage Technology user interface. And it isn't launched on versions is higher 11.2.
The report of dxdiag and the system report of version 11.2 I will lay out in the evening.
System Report Intel Rapid Storage Technology 11.2
SystemReport.тхт
http://rghost.ru/45190460 http://rghost.ru/45190460
DxDiag report
DxDiag.txt
http://rghost.ru/45190420 http://rghost.ru/45190420
SSD PX-128M5S
DArce
Telemeh,
Please post the reports directly to this support forum and not through a third party site.
Sorry, did not understand how to attach a file to your post ...
SystemReport.txt
Системный отчет
Системная информация
Имя ОС: Microsoft Windows 7 Профессиональная
Версия ОС: 6.1.7601 Service Pack 1 7601
Системное имя: BIG
Производитель системы: System manufacturer
Модель системы: System Product Name
Процессор: GenuineIntel Intel64 Family 6 Model 42 Stepping 7 3,301 ГГц
BIOS: American Megatrends Inc., 3602
Технология хранения Intel® Rapid
Установлен комплект: 11.2.0.1006
Версия пользовательского интерфейса: 11.2.0.1006
Язык: Русский (Россия)
RAID-контроллер Intel: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Число портов SATA: 6
Версия ПЗУ RAID оption: 12.5.0.1815
Версия драйвера: 11.2.0.1006
Версия ISDI: 11.2.0.1006
Информация об оборудовании
Емкость: 932 ГБ
Свободно: 0 ГБ
Кэш данных диска: Включено
Число томов: 1
Том-участник: RAID0
Число дисков: 2
Диск массива: WD-WMAYP2706432
Диск массива: WD-WMAYP2552833
Состояние: Нормальное
Тип: RAID 0
Емкость: 931 ГБ
Размер полосы данных: 128 КБ
Кэш обратной записи: Включено
Системный том: Нет
Инициализирован:Да
Ошибки проверки:0
Блоки с ошибками носителя:0
Размер физического сектора: 512 байт
Размер логического сектора: 512 байт
Родительский массив: Array_0000
Число дисков: 2
Диск на порте0
Расположение порта: Внутренний
Тип: Твердотельный диск
Использование: Доступен
Емкость: 119 ГБ
Серийный номер: P02240102129
Модель: PLEXTOR PX-128M5S
Микропрограмма: 1.03
Системный диск: Нет
Защита паролем:Нет
Функция "Native Command Queuing": Да
Скорость передачи SATA: 6 Гб/с
Размер физического сектора: 4096 байт
Диск на порте1
Тип: Жесткий диск
Емкость: 466 ГБ
Серийный номер: Z2A7VW47
Модель: ST3500413AS
Микропрограмма: JC4B
Системный диск: Да
Защита паролем:Нет
Диск на порте2
Тип: Жесткий диск
Использование: Диск массива
Емкость: 466 ГБ
Серийный номер: WD-WMAYP2706432
Модель: WDC WD5003ABYX-01WERA1
Микропрограмма: 01.01S02
Системный диск: Нет
Защита паролем:Нет
Скорость передачи SATA: 3 Гб/с
Диск на порте3
Тип: Жесткий диск
Емкость: 466 ГБ
Серийный номер: WD-WMAYP2552833
Системный диск: Нет
Защита паролем:Нет
Диск на порте4
Использование: Неизвестный
Емкость: 0 ГБ
Серийный номер:
Модель: SONY DVD RW AD-7280S
Микропрограмма: 1.60
Системный диск: Нет
Защита паролем:Нет
Кэш данных диска: Выключено
Функция "Native Command Queuing": Нет
Скорость передачи SATA: 1.5 Гб/с
Размер физического сектора: 0 байт
Размер логического сектора: 0 байт
Диск на порте5
Емкость: 0 ГБ
Серийный номер:
Модель: PIONEER BD-RW BDR-207D
Микропрограмма: 1.30
Системный диск: Нет
Защита паролем:Нет
System Report
System Information
OS name: Microsoft Windows 7 Профессиональная
OS version: 6.1.7601 Service Pack 1 7601
System name: BIG
System manufacturer: System manufacturer
System model: System Product Name
Processor: GenuineIntel Intel64 Family 6 Model 42 Stepping 7 3,301 GHz
Intel® Rapid Storage Technology
Kit installed: 11.2.0.1006
User interface version: 11.2.0.1006
Language: English (United States)
Intel RAID controller: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Number of SATA ports: 6
RAID option ROM version: 12.5.0.1815
Driver version: 11.2.0.1006
ISDI version: 11.2.0.1006
Hardware Information
Available space: 0 GB
Disk data cache: Enabled
Number of volumes: 1
Volume member: RAID0
Number of disks: 2
Array disk: WD-WMAYP2706432
Array disk: WD-WMAYP2552833
Status: Normal
Type: RAID 0
Data stripe size: 128 KB
Write-back cache: Enabled
System volume: No
Initialized: Yes
Verification errors found: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Parent array: Array...
J280
Just tried the newly released IRST v12.5.0.1066.
No improvement, same problem as before. ("Assertion Failed" error, followed by "Unknown Error" in the software)
Is this ongoing issue caused by an unresolved bug with the software, or is it more likely to be due to a problem with my system?
Perhaps I have reached the point where I should re-install my operating system from scratch.
Maybe that is now the only way to get this software to work properly.
Any helpful advice at this point would be very welcome.
Thank you.
Jim.
DZand
Is this ongoing issue caused by an unresolved bug with the software, or is it more likely to be due to a problem with my system?.
Since there are only a very few users, who have reported about problems with the v12 RST software, I suspect, that you got a mismatch of some registry entries. This can be caused by the switches of the Intel RST drivers and software versions you have done.
I totally agree with you. That is the best way to eliminate all file and registry residues of the previously installed RST drivers and software versions.
Good luck!
Fernando
J280
The next question is....
Could the problem I am having with IRST have anything to do with my Windows 8 installation being an upgrade from Windows 7, rather than a clean install?
Thanks for the help so far.
Jim
DZand
That seems possible, if you installed Win8 onto the same partition as your previously used Win7. It is always better to do a clean OS installation.
Just do a google search and you will find the way how to get a Win8 Upgrade version properly and clean installed.
