Rapid Storage Technology
Intel® RST, RAID
Intel RST: BSOD & Slow Start
EMede
I installed the latest version of the Intel RST driver (12.9.0.1001), but since I installed it I have been having problems with booting up and shutting down.
The symptoms are as follows:
  • When I boot for the first time, I often (but not always) get a BSOD with the message DRIVER_POWER_STATE_FAILURE
  • When I then reboot, it works but takes a very long time (2 mins 30 seconds, where it was under 1 min previously and under 30 secs originally)
The same issues apply when waking from S4 Hibernation. The laptop seems to work fine once it has booted.
I applied a trace on the boot using the Windows Performance Toolkit (xbootmgr -trace), and it shows a period of 2 minutes before the start of any hard drive activity. I have attributed this to an issue accessing the SSD following the installation of the iRST driver.
My hardware is as follows:
  • Laptop: Asus UX32VD
  • Intel Series 7 Chipset Family
  • SSD: Samsung 840 EVO (1gb)
  • SATA port set to AHCI mode in BIOS
I am happy to provide the .etl file showing the slow boot time (it is over 1gb so can't attach here, but I did attach the .xml summary). Unfortunately I don't get a dump from the BSOD, presumably because the issue is with the drive and the dump can't be written.
Elie
EMede
Hi Allan,
Thanks for getting back - that seems to have resolved the issue.
I tried:
  • booting (still a 30sec inactivity period, but much better than 2 mins)
  • hibernating now works
  • restarting a few times - no BSOD so far
Thanks very much for the suggestion. I'll report back here if I notice any further problems, but based on brief testing I'm happy this is resolved.
Thanks!
Elie
