Rapid Storage Technology
Intel® RST, RAID
Intel RST - Offline Member
ML68
Hi
I have/had a RIAD 5 array using 6 4TB disks on Windows 10 Pro.  The disks were set up as a 20T windows disk.  One disk went faulty so I shutdown, unplugged the disk and replaced with a new disk.  The storage was working fine at this point but degraded (a little slow).   I went into Intel Optane Storage management software to add the new disk.   The interface was still showing the old disk, not the new disk and there was no option to rebuild.  I rebooted and this time Optane Management showed the RAID array was no longer there.  The disks were visible but there was no RAID volume.  I did not attempt to rebuild the RAID array as I feared I would lose my data.  I rebooted again and went into the pre-OS storage config utility (CTRL-I).  All 5 disks from the RAID array say "Offline Member".
Can anyone help me recover from this?
Earl_Intel
Hi ML68,
I will further check on this issue, I will provide an update on this thread as soon as possible.
Earl E.
Earl_Intel
Hi ML68,
Please consider the following steps:
1. Verify that all disks are securely connected and recognized by the BIOS.
2. Launch the Intel Optane Storage Management software.
3. If the new disk is not detected, try refreshing the interface or restarting the software.
Additionally, you can refer to our "How to Rebuild the RAID1 Volume" article, as the process should be similar for RAID5.
May I know if you're using the latest Intel® Optane™ Memory and Storage Management application from the Microsoft Store?
Earl E.
Earl_Intel
Hi ML68,
Earl E.
Earl_Intel
Hi ML68,
Since I haven't received a response from you, I will go ahead and close this inquiry. If you need any further assistance, please submit a new question, as this thread will no longer be monitored.
Earl E.
