Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
Intel® rapid storage technology ERROR 0xA005004E
YPetr2
Hello.
I have a problem.
I can not understand the reason.
Intel Core i5-3570K CPU
GA-Z68AP-D3 rev.2 motherboard
HGST HUS722T2TALA604 HDD
KINGSTON SMS200S330G mSata SSD
System Report
System Information
OS name: Microsoft Windows 7 Ultimate
OS version: 6.1.7601 Service Pack 1
System name: DOMINAT
System manufacturer: Gigabyte Technology Co., Ltd.
System model: To be filled by O.E.M.
Processor: GenuineIntel Intel64 Family 6 Model 58 Stepping 9 3.801 GHz
BIOS: American Megatrends Inc., Ua9
PCH: 0x1C44
Intel® Rapid Storage Technology enterprise Information
Kit installed: 15.9.0.1015
User interface version: 15.9.0.1015
Language: English (United States)
RAID option ROM version: 11.1.0.1413
Driver version: 15.9.0.1015
ISDI version: 15.9.0.1015
Storage System Information
RAID Configuration
Array Name: SATA_Array_0000
Available space: 2 MB
Number of volumes: 1
Volume member: Cache_Volume
Number of array disks: 1
Array disk: 50026B723C0A3E74
Disk data cache: Enabled
Volume name: Cache_Volume
Status: Normal
Type: RAID 0
Usage: Cache volume
System volume: No
Data stripe size: 128 KB
Write-back cache: Off
Initialized: Yes
Parity errors: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller
Type: SATA
Mode: RAID
Number of SATA ports: 3
Volume: Cache_Volume
Number of spares: 0
Number of available disks: 2
Rebuild on Hot Plug: Disabled
Manufacturer: Intel Corporation
Model number: 0x2822
Product revision: 5
Direct attached disk: WMC6N0E06RY3
Direct attached disk: 5YD2SEZZ
Direct attached disk: 50026B723C0A3E74
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Available
System disk: Yes
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: HGST HUS722T2TALA604
Serial number: WMC6N0E06RY3
SCSI device ID: 0
Firmware: RAGNWA05
Disk on Controller 0, Port 2
Status: Normal
Type: SATA disk
Usage: Available
System disk: No
Command queuing: None
Transfer rate: 3 Gb/s
Model: ST2000DL003-9VT166
Serial number: 5YD2SEZZ
SCSI device ID: 0
Firmware: CC98
Physical sector size: 4096 Bytes
Disk on Controller 0, Port 5
Status: Normal
Type: SATA SSD
Usage: Cache device
System disk: No
Model: KINGSTON SMS200S330G
Serial number: 50026B723C0A3E74
SCSI device ID: 0
Firmware: 60AABBF0
YPetr2
I solved the problem.
Installed and removed:
Intel® RST v.12.8.0.1016 - Does not work.Recommended by the motherboard manufacturer.
Intel® RST v.12.9.0.1001 - Does not work.
Intel® RST v.15.9.0.1015 - Does not work.The latest version.
Installed Intel® RST 15.2.16.1060
Everything is working.
The case where the new driver does not work correctly on old hardware.
mhytt
Hello, could you try this workaround fix?
If it worked, please let us know
YPetr2
YPetr2
