Rapid Storage Technology
Intel® RST, RAID
2244 Discussions
Lexar NM620 is not recognized by Intel RST
RomualdsCirsis
Dear Intel,
Our customer bought from us 2x Lexar NM620 (M.2 2280 PCIe G3x4) 1TB
P/N: LNM620X001T-RNNNG
with Supermicro motherboard MBD-X12SAE-O & CPU Core i9-10900KF.
The customer was unable to create Intel Rapid Storage RAID 1 in BIOS using your M.2 and returned the PC to us. We tested M.2 - they look fully functional and are detected by the motherboard. So we created the ticket at Supermicro support team.
After investigation, we figure out the motherboard bios setting and the RST version seems to be right/up to date. Then we took 2x cheapest Kingstom SSD, and they were detected by BIOS RST successfully.
Next, we took Lexar NM620, and tested it in ASUS and Gygabyte on two different motherboards (other chipsets/config), and the SSD Lexar NM620 are not visible for RAID there too.
We assuming that problem is in Lexar or Intel RST software / version.
Can you assist us in this case? What information do you need?
The main problem, that since we didn't understand the reason of malefaction we can advice customer proper replacement.
Attached motherboard bios settings.
Labels (3)
Jean_Intel
Hello RomualdsCirsis,
Thanks for waiting for a response.
Since you mentioned that the RST software is working fine when you use Kingston SSD, it seems to be more related to the Lexar NM620. I would recommend contacting Lexar Support to verify the RAID capabilities of the drive.
https://www.lexar.com/contact
Jean O.
Jean_Intel
Jean O.
Jean_Intel
Jean O.
RomualdsCirsis
Hello Jean,
Thank you for your reply. We created ticket at Lexar couple days ago and still waiting for respond.
Can I ask one more question to you, from NVMe type and version is it supported by RST? maybe we are missing some stop factor?
We have limited number of M.2 SSD available, maybe the problem is in it type?!
Like it is used as PCIe or switching to SATA?!
IDK
I will appreciate any your suggestion.
RomualdsCirsis
Today we tested AData SX8200PNP (XPG SX8200 Pro PCIe Gen3x4 M.2 2280) 1TB which has pretty similar specs to Lexar NM620 - and it was recognized by the motherboard and Intel RST successfully.
