Rapid Storage Technology
Intel® RST, RAID
RAID 0 - TRIM...
Kurunglu
Hi. I have a portable computer with a 12950HX processor and RAID 0 with two SSD drives. Is it possible to run an TRIM command to optimize the raid disk. Thanks...
Hugo_Intel
Hello Kurunglu
Thank you for posting on the Intel Communities.
Based on the following article TRIM should be possible in a RAID 0 if you are using Intel® Rapid Storage Technology (Intel® RST), however, you will need to check further compatibility with your SSD manufacturer.
Hugo O.
Intel Customer Support Technician.
Hugo_Intel
Hello Kurunglu
I hope you are doing fine.
Were you able to check the previous post?
Let us know if you still need assistance.
Best regards,
Hugo O.
Kurunglu
Hi. I am actually checking if my drive support TRIM in RAID. But i am a bit sad because i did the TRIM and i feel like my bluetooth audio do cracking noise... Thanks...
Hugo_Intel
Hello Kurunglu
Thank you for the information. Enabling TRIM should not interfere with or be related to a Bluetooth issue, please let me know the following:
1.-Did the issue start right after setting up TRIM on your device?
2.-Does the issue happen with any Bluetooth Audio device that you connect to the computer?
3.-Please run the Intel® System Support Utility and attach the resulting log file to know your system and wireless adapter make and model.
Hugo O.
intel Customer Support Technician.
Hugo_Intel
Hello Kurunglu
Hope you are doing well!
Please let us know if you still require assistance in regard to this issue.
Hugo O.
Hugo_Intel
Hello Kurunglu
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards,
Hugo O.
