In the Detailed Description of the current RST drivers, it says:
The Intel® Rapid Storage Technology (Intel® RST) Driver20.2.6.1025.2 supports 12th Gen up to 13th Gen Intel Core platforms.
Intel® VMD support on 11th up to 13th Generation platforms only with an Intel® VMD capable BIOS.
Source
Is there a different driver for the Core Ultra Series 1 and 2?
Where canI find the "F6 driver" to install Windows with VMD enabled?
Is Intel no longer providing them?
Thanks and best regards, Martin
Hello MFess,
- What is the brand and model of your system?
- Can you provide more details on why are you asking for this information?
- Are you getting an error message on your RST?
- Did you create a RAID volume? If yes, please provide more information about the volume?
- Can you share some screenshots if you are having issues.
- Please provide the brand and model of the drives that you are using.
Michael L.
The Intel® Rapid Storage Technology (RST) Driver version 20.2.6.1025.2 supports Intel® Core Ultra Series 1 and 2 processors, facilitating RAID configurations and enabling Intel® Volume Management Device (VMD) functionality on 11th to 13th Gen platforms. Intel
To install the F6 driver during a clean Windows installation, you can extract the necessary files from the SetupRST.exe installer. This process involves running the installer, selecting the "Extract" option, and saving the files to a USB drive. During Windows setup, when prompted to load a driver, you can browse to this USB drive and select the appropriate driver files. MSI
Intel no longer provides the F6 driver in a ZIP format for manual extraction. However, by following the extraction method outlined above, you can obtain the necessary files for a clean installation.
Hello MFess,
Thank you for the assistance.
Michael L.
Hello MFess,
I am sending another follow up on the information that I requested.
Michael L.
