Rapid Storage Technology
Intel® RST, RAID
2200 Discussions
RST service Not running with new SSD SATA
ESanc26
I recently changed my secondary drive form HDD to a SSD, now there is a small icon that shows that RST service is not running. I tried to update, to change settings/preferences to automatic and also to initiate it manually through the services window. It starts but after one second it stops.
n_scott_pearson
Why do you have the RST package installed? You should only have it installed if you are using RAID or you have either an Optane Memory module of a Optane Memory SSD installed. If you meet none of these criteria, uninstall the package; you don't need it and it is doing nothing for you.
ESanc26
Thank you! I'm no expert in this matter, I don´t know why I have it. The new SSD (Ultimate SU800) uses 3D Nand, and the other SSD is a SATA M.2, both on an Inspiron Dell Laptop. I've checked and it seems that I don´t have an Optane Memory module and I'm not using RAID.
n_scott_pearson
Ah, it's a Dell. Dell has this horrible, annoying habit of clumping together all of the packages that might be used with a particular model, regardless of whether or not your particular SKU of this laptop has all of these features enabled/installed. Unless you plan to use RAID or Optane, you shouldn't be told to install RST (yet they do tell you that).
