Rapid Storage Technology
Intel® RST, RAID
2223 Discussions
Rapid technology Mirror issue
BAL-H1
Hello, first of all thank you for reading this.
I bought less than a year ago an acer predator 17.
Acer Predator 17 G9-793
Windows 10 Home
Intel core i7-6700HQ
Nvidia GeForce GTX1060
8GB DDR4 Memory
128GB Storage + 1000GB HDD
Yesterday a notification of intel appears I click on it not really knowing what I'm doing, I read that i can turn my two disk into one volume, which i did again not really knowing what I was doing.
Now i lost access to my HDD, I can't go back ( at least I don't know how), only one disk appears in my storage and i don't know what to do.
Thank you again, to all those who will take the time to read my post.
Hi Nos03,
Thank you for bringing this to my attention, I understand you had selected to mirror the system. Let me help you on this matter.
RAID1 or mirror will require minimum of two drives, this means you had 128GB Storage + 1000GB HDD and the system created one drive with 119 GB of size.
I am not familiar with the computer BIOS configuration but you need to access the RAID BIOS utility and set disks to Non-Raid. This will detach disks off the RAID volume.
In order to enter the RAID BIOS you normally hit CTRL + I, you may need to check with http://community.acer.com/ Acer for further instructions.
Hope it helps.
Allan J.
BAL-H1
Thank you a lot I'll try that immediately.
Hello Nos03,
Yes, please try it and let me know your findings.
Thank you for your time.
Allan J.
BAL-H1
hello again, so I tried CTRL+I but it seem that with acer it's not possible to access the RAID BIOS that way, I tried to follow the solution provided http://community.acer.com/t5/Predator-Laptops/Predator-G9-793-78CM-Disable-Raid-0/m-p/494000 here, but I wasn't able to access the RAID BIOS either way.
I tried to use the RST but couldn't access it either.
So I'm stuck again.
Thanks again for your help.
n_scott_pearson
If RAID is not enabled in BIOS, it won't support pressing CTRL-I. Look for this parameter in the SATA configuration parameters in BIOS. Change mode from AHCI to RAID.
Hope this helps,
BAL-H1
it was already the RAID mode, still I can't use CTRL+I, and I can't modify it because it's all gray.
n_scott_pearson
Then it's time to contact your vendor's customer support and ask how it is done...
BAL-H1
Thanks to all of you, I was able to fix my problemes.
For all of those that might have the same issue http://community.acer.com/t5/Predator-Laptops/RAID-issue/m-p/523515# M6190 here's a link to my salvation ^^.
