Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
SAMSUNG Magician Compatibility Issue / Samsung SSD 850 EVO mSATA 500GB
Marababol
"DRIVER | Intel Corporation 12.9.4.1000 //
Under the current system environment, some functions in Magician CANNOT be run."
I checked and it is already running IRST version 12.9.4.1000 so I do not know what is wrong.
I'm using latest Windows 10 Pro version 21H2.
Thank you in advance for your help!
More information:
What is the model of the motherboard? Model 6-71-(15E0-D06 6-71-P15E0-D05A
If this is a laptop, what is the model of it? SAGER NP9150 (Clevo P150em)
What is the version of the SAMSUNG Magician currently being used? version 7.1.1.820
Is this a new computer? No
When did you purchase it? approximately 9 years old (2013)
Just to make sure, the problem is that after installing the Intel® RST software/driver the SAMSUNG Magician does not work properly? Is that correct? Please provide a detailed description of the problem.
SAMSUNG Magician is informing the following issue:
"There is a reported compatibility issue:
Under the current system environment, some functions in Magician CANNOT be run. To enable these Magician functions and ensure optimal performance it is recommended to: Visitwebsite below and update driver to the latest version:
https://downloadcenter.intel.com/product/55005/-RST"
>>> I checked my system and it appears that Intel® RST 12.9.4.1000 is already installed.
>>> So I do not know what is exactly wrong and why I am getting this error message.
Was SAMSUNG Magician working fine before? Yes when I was still using Windows 7. It is also working under Windows 10 but this little problem appears and I don't know what's wrong.
When did the issue start? I don't know. I only noticed it today.
Did you make any recent hardware/software changes that might cause this issue? No
Which Windows* version are you using? Windows 10 Pro version 21H2
Does the problem happen at home or in the work environment? Home
>>>> See file attached (SSU.Report.txt)
Please help... Thanks!
Steven_Intel
Hello Marababol,
In order to better assist you, please provide the following information:
  • Have you reported this issue to Samsung support?
  • Is the Intel® RST software working fine on your system?
It seems you are using an old version of Intel® RST, which is no longer available in our Download Center, therefore, it is very possible there would be no fix for issues (if any), since there are newer versions for non-discontinued Intel processor generations.
I look forward to hearing from you.
Steven G.
Marababol
Hey Steven,
To answer your queries:
  • Have you reported this issue to Samsung support?  Yes, I've sent a report to Samsung but they have not replied back yet.
  • Is the Intel® RST software working fine on your system? Yes, Intel® RST appears to be working fine.
With regards to your observation that I am using an old version of Intel® RST - Yes you are correct that this is an older version. I did an Intel Driver Support Assistant check and it reports that all my drivers are up-to-date for my system. I also manually downloaded the latest version of RST from your website but when I attempt to install I get an alert that it will not work on my system. Perhaps this version of Intel® RST I have on my computer which is IRST version 12.9.4.1000 is probably the last version that is compatible with my system.
Cheers!
Steven_Intel
Thank you for your response.
As you mentioned before, the latest version of RST will not work on your system, since it is not compatible.
Since the Intel® RST software is working fine on your system, our best recommendation is to get further support from Samsung, as their software is the one failing to work properly.
Steven G.
