Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
SATA available Disk : Removed
harsha_07
when i am trying to access D drive in my laptop it is throwing error " SATA Available disk : Removed " .  after that D Drive is not showing.
kindly help me as i have important data in that drive.
Thanks in advance
n_scott_pearson
This is usually a symptom of a drive that is starting to fail. You may be able to get it running again by powering the laptop off, waiting a minute, and then powering it back on - but understand that this doesn't mean that the failure has been avoided; get your data copied off this driver while you can because it *is* going to fail completely soon.
Hope this helps,
