Rapid Storage Technology
Intel® RST, RAID
2252 Discussions
incompatibility between RST software and windows 10 update version 1903
jhuar2
on Asus laptop equipped with intel RST software, impossible to update to win 10 version 1903.
tried the following without success after several blocked update processes
  1. re install a completely new version of windows (factory installation on asus laptop)
  2. install the latest version of your RST driver Version: 17.5.1.1021 (Latest) Date: 7/10/2019 (version 15 mentioned by microsoft is marked as out of date....on your site)
  3. let windows make the adequate cumulative updates
  4. let windows start update to 1903
The result is negative (same error message as mentioned hereunder)...
what does Intel recommends in this situation which is rather unconfortable as windows continuously tries to push update 1903 .....
Thanking you in advance for your cooperation
AlHill
Go to windows/system32/drivers, and rename iastora.sys to iastora.tmp, then do your 1903 upgrade.
Doc
