Rapid Storage Technology
Intel® RST, RAID
2223 Discussions
my raid is disabled ...help me out to re - enable in RST
jchau6
pls help me...my raid is disabled which is cache disk...i dnt have any idea about that...every time i start my laptop it shows me to press ctrl + i...starting is very slow...in rapid storage technology the accelerate device is inaccessible...help me pls...
some time in the rapid storage technology the status shows me as below image..which ssd port is shows me OFFLINE..
sometimes shows me this error...
and
when i bought this system the start up were very fast,,and doesnt shows me ctrl + i error..
But now the start up is very slow...and every time when i start the system it shows me to press ctrl + i and when i press that it shows me first image of this discussion...after i exit it and system will run but it is very slow....help me...
Jose_H_Intel1
You may want to uninstall and reinstall Intel® Rapid Storage Technology since the last message appears to indicate the software is not working properly. You may also consider updating the BIOS for your system, please refer to the computer manufacturer about this.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Software+Products&ProductLine=Chipset+Software&ProductProduct=Intel%C2%AE+Rapid+Storage+Technology+(Intel%C2%AE+RST)&ProdId=2101&LineId=1090&FamilyId=42 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Software+Products&ProductLine=Chipset+Software&ProductProduct=Intel%C2%AE+Rapid+Storage+Technology+(Intel%C2%AE+RST)&ProdId=2101&LineId=1090&FamilyId=42
Intel® Rapid Storage Technology (Intel® RST) user guide
http://download.intel.com/support/chipsets/imsm/sb/irst_user_guide.pdf http://download.intel.com/support/chipsets/imsm/sb/irst_user_guide.pdf
There is also the possibility that the Cache/RAID volume became corrupted. In such case you may need to delete/remove the cache from the IRST window (or CTRL-I) and recreate it. Please verify with the system specifications or system manufacturer what type of acceleration/caching technology is being used with your system. Remember it is recommended to back up your data before making any change.
Intel® Smart Response Technology user guide
http://download.intel.com/support/chipsets/sb/intel_smart_response_technology_user_guide.pdf http://download.intel.com/support/chipsets/sb/intel_smart_response_technology_user_guide.pdf
http://www.intel.com/support/chipsets/sb/CS-032826.htm http://www.intel.com/support/chipsets/sb/CS-032826.htm
Intel® Rapid Start Technology user guides
http://www.intel.com/support/motherboards/desktop/sb/CS-033637.htm http://www.intel.com/support/motherboards/desktop/sb/CS-033637.htm
Jose_H_Intel1
jchau6
thnk u so much...my system now react normaly...thnk u once again
NG4
Hello Jyubil,
what did you do to resolve your problem? Updated the BIOS? or reinstall Intel® Rapid Storage Technology?
Please let me know.
I have the same issue.
Thanks in advance.
NaNa
