Server Products
4819 Discussions
BMC LAN MAC Adress 00:00:00:00:00:00
YNguy1
I have configured my BMC LAN for a static configuration using ipmitool. Once I was done I tried pinging it and didn't get a response. I noticed that my mac address was 00:00:00:00:00:00 but everything else looks correct. Has anyone seen this before or figured out how to correct it?
Intel Server Board - S7200AP
BIOS Version - S72C610.86B.01.02.0072.041620172102
# ipmitool lan print 1
Set in Progress : Set Complete
Auth Type Support : MD5 PASSWORD
Auth Type Enable : Callback : MD5 PASSWORD
: User : MD5 PASSWORD
: Operator : MD5 PASSWORD
: Admin : MD5 PASSWORD
: OEM :
IP Address Source : Static Address
IP Address : XX.XX.XX.XX <-- omitted IP address
Subnet Mask : 255.255.255.0
MAC Address : 00:00:00:00:00:00 <--- WHY?
SNMP Community String : public
IP Header : TTL=0x00 Flags=0x00 Precedence=0x00 TOS=0x00
BMC ARP Control : ARP Responses Enabled, Gratuitous ARP Disabled
Gratituous ARP Intrvl : 0.0 seconds
Default Gateway IP : XX.XX.XX.XX <-- omitted GW.
Default Gateway MAC : 00:00:00:00:00:00
Backup Gateway IP : 0.0.0.0
Backup Gateway MAC : 00:00:00:00:00:00
802.1q VLAN ID : Disabled
802.1q VLAN Priority : 0
RMCP+ Cipher Suites : 0,1,2,3,4,6,7,8,9,11,12,13,15,16,17,18
Cipher Suite Priv Max : Xaaaaaaaaaaaaaa
: X=Cipher Suite Unused
: c=CALLBACK
: u=USER
: o=OPERATOR
: a=ADMIN
: O=OEM
# ipmitool bmc info
Device ID : 33
Device Revision : 1
Firmware Revision : 1.00
IPMI Version : 2.0
Manufacturer ID : 343
Manufacturer Name : Intel Corporation
Product ID : 117 (0x0075)
Product Name : Unknown (0x75)
Device Available : yes
Provides Device SDRs : no
Additional Device Support :
Sensor Device
SDR Repository Device
SEL Device
FRU Inventory Device
IPMB Event Receiver
IPMB Event Generator
Chassis Device
Aux Firmware Rev Info :
0x01
0x07
0x40
0x28
Thank you so much for your help.
Hello yn281,
BMC with MAC address like this is very weird.
Normally can be related to wrong BIOS.
The recommendation will be to run the latest https://downloadcenter.intel.com/download/27644/Intel-Server-Board-S7200AP-Product-Family-Firmware-Update-Package-for-UEFI-?product=87430 BIOS and if the problem persists will be to contact the support center to get the BMC replace.
If there is anything else we can help please feel free to ask.
Henry A.
Hello yn281,
I just wanted to follow up and verify if the BIOS update resolved your problem.
Henry A.
YNguy1
Hi Henry,
Sorry for that late reply. Thank you for your help. I will keep you posted on it this fixes the problem or not.
Thanks!
Hello yn281,
Thank you for the update, I will await your update with the BIOS update.
Henry A.
Hello yn281,
I just wanted to follow up and verify if you had the opportunity to Flash the BIOS.
Henry A.
Hello yn281,
I am sorry but we haven't heard from you for several days. I will proceed with closing the case. If you require any additional help please feel free to open a new Forum case.
Henry A.
Andy3
I know, this topic is already six years old, but there never was a follow-up and I encountered the same issue and actually managed to fix it after reverse engineering a bunch of things and doing a lot of detective work. I wrote it up here in case anybody else has this issue and would like to dig into this.
https://www.geekatwork.de/2024/repairing-ipmi/
