I recently bought a S5500BC on ebay and its doing its job well. But the fans are allways at 100% and i would prefer a little bit more silence. I have updated my firmware (incl. BIOS) and nothing changed. I found a post about fan speeds in non-intel chassis ( ) but if i look in my BC_BMC.sdr i cannot find 100% aka 64h settings. Does anyone knows what i need to change in my config?
// Chassis Fan Control Domain 1 with profile 6,7 for Minimum
// For Other Chassis (Medium ramp)
// Fan Control Domain Number # 1 (PWM0: Processor1&2 Fan)
_SDR_TYPE C0
_SDR_TAG 'OTHER_MR'
_REC_LEN 001F
// Sensor Record Header
00BD // Record ID
51 // SDR Version
C0 // Record Type
1A // Record Length
// Record Body Bytes
570100 // Manufacturer ID
0C // Record Subtype Value (Fan Speed Control SDR Record, rev 2)
// Temperature Fan Control Record
01 // Record Version
01 // Fan Control Domain Number # 1 (PWM0: Processor1&2 Fan)
14 // Normal Control Value (14h = PWM 20%)
FF // Boost Control Value (FFh = use boost sub record)
01 // Ramp Step (1=1%)
02 // Scan Rate (2 Cycles)
C0 // Fan Profile Support = 11000000
// Stepwise Linear type Temperature Sensor Sub-record
20 // Sensor Owner ID
20 // Temperature Sensor Number -- (BB Amb)
64 // Temp Sensor failure control Value (64h = PWM 100%)
00 // Sleep Control Value
41 // [7:6]-Supported in S1 (1=yes); [5:3]-Reserved; [2:0]-Control Type (001b=Stepwise linear)
10 // Temperature Info [7]-Reserved; [6]-Domain Maximum=0; [5:3]-Negative Hysteresis=2; [2:0]-Positive Hysteresis=0
04 // Count of Temperature/Control Value Pairs (04h=4)
00 // Temperature 1 0c
33 // Control Value 1 (Percentage) (33h = PWM 51%)
14 // Temperature 2 20c
33 // Control Value 2 (Percentage) (33h = PWM 51%)
1E // Temperature 3 30c
33 // Control Value 3 (Percentage) (33h = PWM 51%)
3C // Temperature 4 60c
64 // Control Value 4 (Percentage) (64h = PWM 100%)
Also i am not sure which entries to alter and which not. Would appreciate any help,
SinTh0r4s
- Tags:
- CPU
We regret to inform you that the board you are looking support is end of interactive support (EOIS) so the only source of assistance is our website:
http://www.intel.com/content/www/us/en/support/server-products/server-boards/legacy-server-and-workstation-boards/intel-server-board-s5500bc-family/intel-server-board-s5500bc.html Intel® Server Board S5500BC
