Server Products
4785 Discussions
Difference between LGA775 Xeon CPUs and its desktop counterparts
hi there,
if somebody could throw some light on this please:
what are the differences between LGA775 Xeon CPU´s and its desktop counterparts, such as Intel Xeon UP E3110 and
Intel Core 2 Duo E8400?
also i´m wondering if a 1:1 FSB:RAM Ratio would be the way to go for me as i´ve got 667Mhz ram modules - so i would need a 1333FSB CPU?
thank you
Hi there,
Difference between the CPU E3110 & E8400:
Website: http://ark.intel.com/ProductCollection.aspx?familyID=26547 http://ark.intel.com/ProductCollection.aspx?familyID=26547
Click on Compare
Intel Trusted Execution Technology:
http://www.intel.com/technology/security/downloads/TrustedExec_Overview.pdf http://www.intel.com/technology/security/downloads/TrustedExec_Overview.pdf
Intel Stable Image Platform:
http://www.intel.com/business/bss/products/client/stableplatform/faq.htm?iid=SEARCH http://www.intel.com/business/bss/products/client/stableplatform/faq.htm?iid=SEARCH
Hope this helps a bit. As personally, i dont know much on the Intel Stable Image Platform & Intel Trusted Execution Technology.
Kind Regards,
Aryan.
thanks for your quick answer
that is quite remarkable as the Xeon E3110 is more expensive than the E8400 - so it seems that the E8400 is the better choice?
could you throw some light on the FSB:RAM Ratio thing?
i´ve got an Intel S3210SHLC board, as i´m not able to tweak anything in the bios i´m wondering if a 1:1 FSB/RAM ratio would be the most efficent setting?
to achieve this, i would need a 1333FSB CPU for my 667Mhz Ram, is this correct?
thanks in advance
Hi there,
Let's consider a CPU E5410 in this example.
The Xeon CPU has:
Speed 2.33 Ghz
FSB 1333 Mhz
So here the core frequency to fsb multiplier will be 1/7. [(2.33x1000x4)/1333]
If i am using a memory with speed 1333Mhz, then the fsb:dram ratio will be:
1:1 [1333/[(1333/4)x4]]
Now if you are using a memory with speed 667Mhz, then the fsb:dram ratio will be:
2:1 [667/[(1333/4)x4]]
I think so. I am not 100% sure.
Please investigate further.
Kind Regards,
Aryan.
i calculated it this way:
as Intel´s FSB is "quadpumped" (1333 / 4 = 333,25) i thought that the effective DDR2 frequency (667 / 2 = 333,5) would achieve an 1:1 FSB/RAM ratio
in the end - imho the most efficient setting, or?
maybe another person could chime in here?
is my calculaton correct?
CPU: (1333 / 4 = 333,25) ; DDR2 frequency (667 / 2 = 333,5) = 1:1 FSB/RAM ratio?
aryan, your computation confused me a little
in respect of "Intel Trusted Execution Technology" and "Intel Stable Image Platform" it seems that it isn´t quite important to me
i´m more concerned about the 24/7 capabilities of the E8xxx and Xeon CPUs (LGA775) - are there any drastically differences?
