Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
Intel Modular Server (MFSYS25)
On the Intel Modular Server what is the correct procedure for powering down? and can this be scripted?
Once all hosts are shutdown down and blades are powered off is there a graceful way to kill the power?
Lee
The only way to power off the chassis is to disconnect the power at the back. If you want to power it off remotely then you'll have to find an intelligent power strip you can use to perform that function.
Thanks for the reply.
I thought as much!
Lee
