Server Products
4811 Discussions
Intel Server Board S7200AP
SSoua1
Hello Everybody,
there is anyone knows if we can use the liquid cooling system on Intel Server Board S7200AP and which reference, from which manufacturer?
Thank you in Advance
Hi S.ouarez,
Thank you for contacting Intel Technical Support.
I understand that you need to know if we have or recommend a water cooling system to use on the Intel® Server Board S7200AP. It's a very good question; we haven't had this question before. Let me investigate this and get back to you with information. In the meantime, do you have any specific model or brand in mind?
Jeremiah A.
By the way,
As part of the research, can you please confirm if you are using a third party chassis, and if so, can you indicate the model?
Jeremiah A.
SSoua1
Hi Jeremiah,
I am Intel VSC Agent in Germany in DCG Division, I got this question from one of my reseller.
I spoked to my reseller they use Intel Chassis here's the reference: H2312XXLR2
Best regard,
Sidiki
SSoua1
Hi Jeremia,
Thank you for looking into it. the model is : BBS7200APL, I show that this one support liquid cooling, but I don't know which one and from which OEM neither the references.
Hi S.ouarez,
According to Intel sites, from the Intel® Server Board S7200AP Family Product, the one that supports Liquid Cooling is the Intel® Server Board S7200APL or Intel® Compute Module HNS7200APL, please see reference link.
https://www.intel.com/content/www/us/en/motherboards/server-motherboards/server-board-s7200ap.html https://www.intel.com/content/www/us/en/motherboards/server-motherboards/server-board-s7200ap.html
Topic: Product Specifications for General Availability
I will investigate if we have a recommended list or if this option is open to your preferences and get back to you as soon as possible.
Jeremiah A.
Hi S.ouarez,
I hope you are doing well today.
To confirm the information about liquid cooling system supported on the Intel® Server Board S7200AP family. The board that supports Liquid Cooling is the Intel® Server Board S7200APL or Intel® Compute Module HNS7200APL. We do not have a list of recommended liquid cooling systems for our server boards; this will be open to the customer preferences.
I hope this information clarified you inquiry.
Jeremiah A.
GRIFFCOMM
Ive never had a good experience with liquid cooling, i accept it "maybe" more efficient but the efficiency is not seen until you are at very high temperatures, as Intel designed the CPU to be used with an Air Cooler, changing to liquid does not make it more efficient unless you want to overclock the CPU which again isnt under Intel's design methods.
In my option if you want to "overclock" then buy a larger CPU and run it as designed, you are adding problems of a whole liquid cooling system to maintain that the board knows nothing about.
Again these are my options so thought i would share them.
Many Thanks
Ashley
Hi S.ouarez,
Thank you for your information, we really appreciate your feedback. Please let us know if there is anything else we can help you with. More than glad to assist you.
Jeremiah A.
Hi S.ouarez,
Jeremiah A.
Hi S.ouarez,
Jeremiah A.
Intel Techncal Support
Hi S.ouarez,
I have not heard back from regarding this case. I will go ahead and close the case. If you need more help from, feel free to contact us; more than glad to assist you.
Jeremiah A.Intel Technical Support
