I noticed that both SLAPL and SLB9J Intel E8400 are supported on the Intel DP43TF motherboard but how come only the SLAPM Intel Xeon E3110 is indicated in the processor list? Does this mean the SLB9C Intel Xeon E3110 is not supported in the Intel DP43TF motherboard?
DP43TF supports E3110 (SLAPM) as I see in the compatibility list however I could not find any compatibility for E3110 (SLB9C).
Board Match: http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DP43TF http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DP43TF
Processor Match: http://processormatch.intel.com/CompDB/SearchResult.aspx?ProcNbr=E3110 http://processormatch.intel.com/CompDB/SearchResult.aspx?ProcNbr=E3110
Board & Processor Match: http://processormatch.intel.com/CompDB/SearchResult.aspx?ProcNbr=E3110&BoardName=DP43TF http://processormatch.intel.com/CompDB/SearchResult.aspx?ProcNbr=E3110&BoardName=DP43TF
There is always a possibility that parts not specified in THOL (Tested Hardware & OS List) might work however I strictly advise users to go according to THOL to avoid any possible mismatch and surprises.
PS: Reply to this post has already been posted at the following URL: http://communities.intel.com/message/11381# 11381 http://communities.intel.com/message/11381# 11381
Warm Regards,
Javed Lodhi
Intel Go Green, Save The Environment!
