Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4807 Discussions
MB S2600WF POST "Fatal error: (MEMORY) memory not detected! E8h
Roman777
The system freezes during POST startup. unable to enter BIOS. tried to reset the BIOS.The server in question is brand new, and the RAM is also brand new. We attempted to test the system with a minimal configuration of 1 CPU and 1 memory module, but this did not yield any results. I have tried 3 different types of RAM: 1. Kingston DDR4 16GB (PC4-19200) 2400 MHz ECC Dual Rank - The server initially booted from this module. 2. Kingston DDR4 DIMM 32GB <PC4-21300> CL19 ECC - North issued a "Fatal error: (MEMORY) Memory not detected! E8h" error. 3. Samsung DDR4 64 GB RDIMM (PC4-25600) - This module is the main one needed to run the server, and it also produced a "Fatal error: (MEMORY) memory not detected!" error when tested. Could you please assist us in resolving this issue?
