Server Products
4785 Discussions
Random fan spin-up on R1304SPOSHBNR
JMcCo12
I have recently purchased three S1200SPOR servers, and they all three are having the same issue: at random intervals, the fans will spin up to max for just a second or two before settling back down. These intervals can be anywhere from a few minutes to an hour, and they do not correlate with server load.
I have upgraded the firmware to S1200SP.86B.03.01.0026.092720170729, check for thermal trips, and examined the SEL, but they didn't help. However, in watching the IPMI sensors, I did notice one correlation: the times when the fans spin up seem to correspond to the sensors being unable to read "P1 Therm Margin". My conclusion was that the system is occasionally unable to read the power supply temperature, so it spins up the fans "just in case", but on the next reading it reads the temperature correctly and so returns the fans to normal.
I checked the sensor wire and it is secure. (Fiddling with it doesn't trigger the fan response either.) I might conclude a hardware fault, but this is happening on all three systems, each of which were purchased at different times over the last few months.
I also found this thread: but the information isn't any help since the SEL doesn't report any errors, the problem is intermittent, I don't have a RAID controller in them, and the standard checks didn't reveal anything promising.
If anyone has any ideas on where to go next, I would appreciate the input.
Thanks!
System info dump (all three set up the same):
OS: CentOS 7
# dmidecode
Getting SMBIOS data from sysfs.
SMBIOS 2.7 present.
64 structures occupying 3770 bytes.
Table at 0x80630000.
Handle 0x0006, DMI type 0, 24 bytes
BIOS Information
Vendor: Intel Corporation
Version: S1200SP.86B.03.01.0026.092720170729
Release Date: 09/27/2017
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 16384 kB
Characteristics:
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 0.0
Firmware Revision: 0.0
Handle 0x0007, DMI type 1, 27 bytes
System Information
Manufacturer: Intel Corporation
Product Name: S1200SP
Version: R1304SPOSHBNR
Serial Number: QSCD74200212
UUID: 71C4BAF6-8AB0-E711-AB21-A4BF0128AAE2
Wake-up Type: Power Switch
SKU Number: SKU Number
Family: Family
Handle 0x0008, DMI type 2, 17 bytes
Base Board Information
Version: H57534-260
Serial Number: QSSA74100091
Asset Tag: Base Board Asset Tag
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Part Component
Chassis Handle: 0x0000
Type: Motherboard
Contained Object Handles: 0
Handle 0x001D, DMI type 4, 48 bytes
Processor Information
Socket Designation: CPU 1
Type: Central Processor
Family: Xeon
Manufacturer: Intel(R) Corporation
ID: E9 06 09 00 FF FB EB BF
Signature: Type 0, Family 6, Model 158, Stepping 9
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Xeon(R) CPU E3-1220 v6 @ 3.00GHz
Voltage: 0.9 V
External Clock: 100 MHz
Max Speed: 4200 MHz
Current Speed: 3000 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x001A
L2 Cache Handle: 0x001B
L3 Cache Handle: 0x001C
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 4
Core Enabled: 4
Thread Count: 4
Characteristics:
64-bit capable
Multi-Core
Execute Protection
Enhanced Virtualization
Power/Performance Control
Handle 0x000E, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x001E
Error Information Handle: Not Provid...
Hello John,
Thank you for contacting Intel Technical Support.
In order to further understand the issue please download the system information retrieval utility from https://downloadcenter.intel.com/downloads/eula/26991/System-Information-Retrieval-Utility-SysInfo-?httpDown=https://downloadmirror.intel.com/26991/eng/Sysinfo_V14_0_Build19_AllOS.zip here, then uncompress the .zip file into a usb key and boot from it. After that run the file sysinfo.efi. This utility will collect log files and system information that we expect will help us figure out what the problem is the server fans.
Franklin S.
JMcCo12
Hi Franklin, thank you for replying. Here are the logs you requested.
For context, the critical events listed in the SEL on the 13th were from me troubleshooting the issue. There have been numerous fan spin-up events since then.
JMcCo12
Because a video is worth a thousand pictures, here is a (bad) recording of the SDR sensors during a fan event. Watch the "P1 Therm Margin" sensor to the bottom and listen for the fans to spin up.
Hello John,
Apparently it is expected for the fans to go full speed when the temperature levels are unreadable. Please check this link https://www.intel.com/content/www/us/en/support/articles/000021781/server-products/server-boards.html https://www.intel.com/content/www/us/en/support/articles/000021781/server-products/server-boards.html it indicates that the problem could be associated with the use of a non validated memory module. On the other hand, there is another link within the same article where it says "Review how to troubleshoot a loud fan scenario" which could be of help but still there is a high chance that using a validated memory module will help.
Franklin S.
Hello John,
I just wanted to check if you had any news on troubleshooting the fan spin up issue that you were experiencing. Thank you.
Franklin S.
JMcCo12
Hi Franklin,
I was out for the Christmas holiday, so I haven't had a chance to work on this in the last couple of weeks. Thanks for following up, though.
I had found those links you provided, but I had discounted them since the symptoms weren't quite the same; namely, the reported SEL entries weren't there. I will see what I can do to get some validated memory, but that may or may not be an option for me. (Budget issues, not distribution issues.)
John.
John,
Hope you had a great holiday season. If you could somehow make a test with validated memory that would be great. I will investigate more to see if I can find more info that points to the specific error message that you are getting but all sources we checked here basically point to the same conclusion with validated memory.
Franklin S.
Hello John,
I checked here and unfortunately there is not much that we can do until the system is tested with validated memory. Thank you.
Franklin S.
Hello John,
Since the best advice we can offer you in this particular case is the use of validated memory we will proceed to close this case. If in the future you have any additional concerns or questions please contact us
Franklin S.
JBeat
Validated memory? Really? That's the best you got?
Here in this link https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&dynamicUser=Y&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1 https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&dynamicUser=Y&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1 you can find a tool that can help you configure compatible hardware for your server. First you would need to select the S1200SPOR board and then the memory category to find the list of validated memories.
Here is a spreadsheet with that information anyways, in case the website becomes a little confusing.
Franklin S.
JBeat
I already have compatible memory...
Now what?
Hello jcbeauty,
For further confirmation, would you please show the output of the command "sudo dmidecode --type 17"?
Franklin S.
JBeat
Are you guys going to try and help us out here or just continuously make us jump through hoops until we give up?
Hi jcbeaty,
We need more information to help you diagnose what could be happening to your system. Please download the system information retrieval utility from https://downloadcenter.intel.com/downloads/eula/26991/System-Information-Retrieval-Utility-SysInfo-%3FhttpDown%3Dhttps%253A%252F%252Fdownloadmirror.intel.com%252F26991%252Feng%252FSysinfo_V14_0_Build19_AllOS.zip here, and then uncompress the .zip file into a usb key and boot from it. After that run the file sysinfo.efi. This utility will collect log files and system information that we need you to share with us afterwards.
Thank you,
Franklin S.
Hi jcbeaty,
This is a quick follow up to see if you were able to gather your server logs so that we can figure out if there are any additional configurations that could be adjusted in order to solve your problem.
Thank you,
Franklin S.
Hi jcbeaty,
Please do not hesitate to contct us if you need further assistance.
Thank you,
Franklin S.
