Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4931 Discussions
S2600CP motherboard + P3600 SSD?
ROles1
I own a S2600CP board with 2x Xeon's on it. It has the newest BIOS package upgrade (BIOS : 02.06.0002 - ME : 02.01.07.328 - BMC : 01.25.9398 - FRUSDR : 1.11)
Now I have gotten a good offer for an Intel P3600 SSD that I wanna use on that board.
I wanna check if I can boot off this SSD card?
I ask because there is this possible issue with NVMe and booting off those.
If not, I won't get the P3600 and just continue to boot off a SSD in a Sata 6Gbps port like I do now.
I do not have access to a free P3x00 card that I can test with, so I need to know for sure the card will work on that board before I proceed.
Thank you for contacting Intel Technical Support.
In order to check compatibility conditions on Intel Server Products I would like to recommend the following tool:
https://serverconfigurator.intel.com/exalt/RequestManager?ServletNumber=1&localinfo=0&RestrictionVal=SVG&APPLICATIONCODE=1 Intel® Server Configurator Tool
If you go to THOL Builder you can try the different validated combinations.
faugub_intel # iwork4intel
