Hello.
We use S2600GZ server board with latest BIOS update (R02.06.0006), 2 x Xeon(R) CPU E5-2630L, 28G RAM, PBA G15038-350 two cards and nVidia Quadro M2000.
With BIOS version 01.02.0006 this configuration works fine. But after BIOS update to 02.06.0006 - system not starting. System show only first screen with BIOS information in cycle (without Intel logo).
When we remove nVidia - system works fine. We have change memory mapping in BIOS ( ) with different values but this don't solved our problem.
Hi FenixVT,
Thank you for using Intel® Community Support.
The latest BIOS of Intel® Server Board S2600GZ is not recognizing properly the nVidia* Quadro M2000 graphics card.
Fenix, I understand the previous BIOS version 01.02.0006 recognized properly the graphics card.
As a workaround please, clear CMOS, unplug the power cable, remove the battery and push the power button 3 to 5 times.
Reseat the battery, plug the USB drive with the latest BIOS https://downloadcenter.intel.com/download/26962/Intel-Server-Board-S2600GZ-GL-Firmware-Update-Package-for-Extensible-Firmware-Interface-EFI-?product=56253 version 02.06.0006. After the update, get into the BIOS, reset it pressing F9 then, press F10.
Get into the BIOS again, 1) disable NIC controllers (Main screen>Advanced>PCI Configuration>NIC Configuration) 2) Disable Dual Monitor Video.
Save changes, turn the system off and place the external graphics card. Please tell me if the system can post or boot.
Miguel C
Hi Miguel,
Thank you for answer!
We using integrated Ethernet port and can disable it only temporary. Also we have Dual Port Intel® 82599EB 10GbE I/O Module AXX10GBNIAIOM with 10G link.
Where we can disable Dual Monitor Video?
Hi FenixVT,
FenixVT, the video options are available using the following:
"Main screen>Advanced>PCI Configuration"
PCI Configuration menu gives the options to change Memory options, Legacy VGA Socket and Dual Monitor Video.
Keep the Memory options as default, make a test using Dual Monitor "enable then disable"
Miguel C
Hi FenixVT,
I was wondering if you have solved the external graphics issue, feel free to post again if you need anything else.
Miguel C
