Dear all,
I am wondering about the best known method for implementing the following operation as part of a complex number multiplication. The input value is a zmm register which contains 4 double complex numbers in the following arrangement {c1.re,c1.im,c2.re,c2.im,c3.re,c3.im,c4.re,c4.im}
I want to separate these into two registers containing all four real parts duplicated and also also for imaginary parts duplicated. I.e.
{c1.re,c1.im,c2.re,c2.im,c3.re,c3.im,c4.re,c4.im} -> {c1.re,c1.re,c2.re,c2.re,c3.re,c3.re,c4.re,c4.re} and {c1.im,c1.im,c2.im,c2.im,c3.im,c3.im,c4.im,c4.im}
At present I am using the following pattern:
one_re = (__m512d)_mm512_shuffle_epi32((__m512i)one,0x44);
one_im = (__m512d)_mm512_shuffle_epi32((__m512i)one,0xEE);
It feels like I might be missing something. Is this the most efficient method for this operation?
Alastair
I found the answer to this using a masked swizzle, which seems very slightly faster.
__mmask8 real_mask = (__mmask8)_mm512_int2mask(170); __mmask8 imag_mask = (__mmask8)_mm512_int2mask(85); __m512d input = {0,1,2,3,4,5,6,7}; __m512d real_parts = _mm512_mask_swizzle_pd(input,real_mask,input,_MM_SWIZ_REG_CDAB); __m512d imag_parts = _mm512_mask_swizzle_pd(input,imag_mask,input,_MM_SWIZ_REG_CDAB);
Alastair
Alastair
Alastair,
Thank you for letting the community know.
Taylor
