Software Archive
Read-only legacy content
64bit licence
filippo_s_
Good morning,
I would ask to a licence number for Windows c++ compiler 64 bit.
Thank you in advance.
Filippo
Hubert_H_Intel
Did you encounrer problms with installing your evaluation product? With an eval installation you don't need a serial number; choose activation mode 'Evaluate....'.
Regards, Hubert.
filippo_s_
Installation was successfully but when I tried to compile a 64 bit application I had the following error:
1>icl: : error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
I read in forum that the solution is asking a license code to Intel people.
What's the right solution?
Best regards.
Hubert_H_Intel
Filippo,
That's actually a bug in the eval activation mode. For compiling 64-bit applications you need a license file. Just sent it to your email.
Regards, Hubert.
Asfandyar_A_
Hi
I am  having the problem with Intel Parallel studio XE 2015.
can you please email me the lic file.
Asfandyar
