Software Archive
Read-only legacy content
17060 Discussions
A Question about SOAP
brianobrien
I wrote a UPnP Internet Gateway Device Class in C++ with raw tcp/ip
and udp calls.
I want to now port that code to a high level interpreter that
supplies
SOAP methods.
I need some help 'filling in the blanks' in this high level language.
Here is the C++ method:
//This code sends a message to the gateway to inquire about the
external IP address. It builds up the soap envelope and message then
posts //it and gets the response, parses it to extract the desired
value.
void IGD::getExternalIPAddress(std::string & NewExternalIPAddress) {
tcpclient poster;
std::string htmlpost, xml;
char buffer[2048];
poster.connect((char *) gatewayIPAddress.c_str(), gatewayPort);
xml += " ";
xml += "http://schemas.xmlsoap.org/soap/
envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/
encoding/
xml += " ";
xml += " "urn:schemas-upnp-
org:service:WANIPConnection:1"/> ";
xml += "
xml += " ";
htmlpost += "POST /control?WANIPConnection HTTP/1.1 ";
htmlpost += "HOST: ";
htmlpost += gatewayIPAddress;
htmlpost += ":";
htmlpost += itoa(gatewayPort, buffer, 10);
htmlpost += " ";
htmlpost += "CONTENT-LENGTH: ";
htmlpost += itoa(xml.length(), buffer, 10);
htmlpost += " ";
htmlpost += "CONTENT-TYPE: text/xml ; charset="utf-8" ";
htmlpost += "SOAPACTION: "urn:schemas-upnp-
org:service:WANIPConnection:1#GetExternalIPAddress" ";
htmlpost += " ";
htmlpost += xml;
poster.send(htmlpost.c_str(), htmlpost.length());
int rc = poster.recv(buffer, sizeof(buffer));
buffer[rc] = '�';
HtmlMsg serverResp(buffer);
checkResponse(serverResp);
std::string xmlText = serverResp.getXml();
xmlObj xmlO(xmlText);
std::cout << xmlO;
xmlEntry e = xmlO.get("s:Envelope/s:Body/
u:GetExternalIPAddressResponse/NewExternalIPAddress");
NewExternalIPAddress = e.getValue();
The REALbasic interpreter provides a brief example of a soap call and
I'm trying to use it, but I don't understand the parameters its
asking
for.
Dim sm as SoapMethod
Dim sr as SOAPResult
// create the soap method and set the parameter(s)
sm = New SoapMethod
sm.parameter("USZip") = "12345"
// set soap method properties
sm.methodNamespace = "http://www.webserviceX .NET"
sm.action = "http://www.webserviceX.NET/GetInfoByZIP"
sm.url = "http://www.webserviceX.NET/uszip.asmx"
// execute the method
sr = sm.invoke("GetInfoByZIP")
// display the Area_Code portion of the result
MsgBox sr.result("Area_Code")
The sm object has these attributes that can be set:
action
connection
inputParams
methodName
methodNamespace
namespaces
paramTypes
timeout
url
wsdl
