- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Sergey,
Could you pls elaborate on How You Solved the problem? that is something I could learn from. I am not faint hearted myself, but the problem described is a programer's nightmare.
The wish to integrate good, proven, compact DOS-based programs and tools into gigantic, super-feature-rich, megabyte-length Windows environment is not so uncommon.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
>>...Could you pls elaborate on How You Solved the problem? that is something I could learn from.
I meant the strategy of attack. The 'list of problems' as a starter is self-evident.
Given the fact that each patch may insert new hidden bugs, a long list of patches ensures troubles. Obviously, you did not do a lengthy point-by-point patch through. Obviously, you had a better strategy.
It was proved to me on my first year, that a normal person (me) can't calculate a 5x5 determinant, using pen and paper in the straight-forward way. How? I checked and re-checked my results, and never got two successive equal numbers. That lesson helped me avoid long lists of patches.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I too am interested in how you tackled this!
By the way, why did you choose Turbo C++ 3, an ancient DOS C++ compiler? It's very impressive that you got it working, but I'm still puzzled why this would be a target. Does ScaLib have DOS users?
If you want a non-GCC, non-MS compiler, especially Borland, why not a modern version of Borland / Embarcadero C++ Builder? If you used, say, Embarcadero C++Builder XE3 (two versions old now) you could have a non-MS but modern 32 and 64-bit C++ compiler. In fact the 64-bit version would be quite useful since it's a brand new compiler for the company based on CLANG. The 32-bit one is decent but would give you some useful compatibility checks; it's not CLANG-based but is the updated descendant of the Borland C++ compiler chain. In addition, you could use it for cross-platform checks, since it compiles for OSX and iOS as well.
This isn't a criticism, just curiosity about why you chose the target you did, and perhaps also a suggestion for a compile target that users of your library might find useful. (I think you'll find more people using C++Builder for Windows, OSX, or iOS than using Turbo C++ for DOS.)
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
