Software Archive
Read-only legacy content
17060 Discussions
ANDROID in windows 8
mohamed_el__mahdi_B_
How can we use ANDROID emulateur with google account(google play, gmail....) int windows 8 ?
Mohamed_helmi_b_
Turns out I was using the image "Android 2.2" instead of "Google APIS (Google Inc)". Using the Android SDK and AVD Manager, create a new virtual machine with the correct image.
Mohamed_Khalil_ZENDA
Hi Mahdi
There are some emulators for Android that let you install and use the Android mobile system, but they do not always work properly and end up giving more headache than help. But who uses Windows 8 has one more trick up his sleeve.
It is an application that simulates the settings on the PC and a smartphone allows you to install almost all apps developed for Google’s mobile OS. Below you will find some tips on how to use this application and use their favorite applications outside of Android.
Google it, and you will find the solution ! A bit hint : Bluestacks !
Enjoy ...
Mohamed_Ali_A_
it's the same think like in windows 7 you must also have the AVD Manager.So just create a new virtual machine
Hyrulia
Same as Windows 7!
nakhli__m_
it's the same, just you need AVD manager then create a new virtual machine :)
HI I was asking how to use android like a real smartphone so i can install applications from play store ... not how to install a simple simulator
Kishor_D_
You can used adb install coomand to install any apk
Sunil_V_
You can run via AVD manager
JLuna5
Hi Mohamed, you might to install vmware virtualizer software and run a image of android, all the function are the same as a phone.
Ashwin_S_Ashok
Bluestacks is a great software that can be used in windows.
it supports in win8 also..
JLuna5
Hi Ashwin S Ashok, thank you good input!
Ashwin_S_Ashok
its ok...JudLup Luna...
main benifit of bluestacks is we can use any android app in windows or mac...
