Software Archive
Read-only legacy content
17060 Discussions
Accelerometer is not working in phone but working properly in emulator
Anjali_P_
Hi
I have created accelerometer example using accelerometer object and its method. It works properly in emulator but not in phone. Please reply as soon as possible.The below function is called on window onload. My code is below :
function init()
    try
        if(intel.xdk.accelerometer)
            alert("accelerometer is supported");
        else
            alert("accelerometer is not supported");
        intel.xdk.accelerometer.getCurrentAcceleration(
            function(acceleration)
                document.getElementById("text").innerHTML = 'Acceleration X: ' + acceleration.x + '\n' + 'Acceleration Y: ' + acceleration.y + '\n' + 'Acceleration Z: ' + acceleration.z + '\n' + 'Timestamp: '      + acceleration.timestamp + '\n';
    catch(e)
alert('catched');}
Thanks & Regards,
Anjali Paria.
John_H_Intel2
Is your init() function being called after onDeviceReady has fired?
You should use the Cordova version of the accelerometer of the plugin, not the intel.xdk version.
Elroy_A_Intel
I recommend using the Accelerometer (device-motion) Cordova plugin. You can find more information at https://github.com/apache/cordova-plugin-device-motion.
Anusha_M_Intel1
Hi Anjali, the xdk plugins are no longer actively maintained. We recommended using the device-motion cordova plugin like Elroy pointed out. You can also refer to the Hello Cordova sample (ships with the XDK) for an example.
 js file with accelerometer code: https://github.com/gomobile/sample-hello-cordova/blob/master/www/js/cordova-acc.js
