Software Archive
Read-only legacy content
17060 Discussions
Activate IPP in Composer XE for Windows
Dorsch__Uwe
I have a valid license for Intel Composer XE for windows.
The license is valid for C++ Composer, Math Kernel Lib and TBB, but the license is not valid for IPP.
But IPP is also a part of the Intel Composer, why is the licenes not valid for IPP.
My support is valid until May 2015, so this will not be the problem.
kind regards
Uwe
Hubert_H_Intel
Hi Uwe,
I'm working on that issue. Yes, IPP cannot activate with a Composer XE license actually, but it seems to be an issue with the Intel® Software Manager only. If you selected the IPP installation with the Composer XE installation everything is fine and IPP is installed. If you need to apply an IPP update, run the installer form the downloaded package, NOT from the Intel Software Manager and use the serial number or license file for installation.
I hope this helps.
Hubert.
