Software Archive
Read-only legacy content
17060 Discussions
Admob cordova plugin problem
Flemming_P_
Construct 2 export as cordova
cordova-plugin-ad-admob
** BUILD FAILED **
The following build commands failed:
    CompileC build/Quiz\ Bornholm.build/Release-iphoneos/Quiz\ Bornholm.build/Objects-normal/armv7/AdMobPlugin.o Quiz\ Bornholm/Plugins/cordova-plugin-ad-admob/AdMobPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
(1 failure)
Error: Error code 65 for command: xcodebuild with args: -xcconfig,.../cordova_project/platforms/ios/cordova/build-release.xcconfig,-project,Quiz Bornholm.xcodeproj,ARCHS=armv7 arm64,-target,Quiz Bornholm,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../cordova_project/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../cordova_project/platforms/ios/build/sharedpch
ANY IDEARS ???
PaulF_IntelCorp
Please post the entire build log as a text file attached to your post.
PaulF_IntelCorp
