Software Archive
Read-only legacy content
17060 Discussions
Advisor error: Cannot load raw collector data
acolovic
Hi all,
I've tried to perform Survey analysis on my project (one exe and many dll-s) and I get the following error while launching the process:
-No Data - Data Loading failed - Error message 0x4000001e - cannot load raw collector data ...
Here is the log from the Output window:
Loading cached program model
Warning: kernel32.dll instrumentation requested more than once ...
Target process's profiling finished but the following processes are still being profiled:
PPID PID STATE NAME
002368 002664 RESUME D:\\prof_tfs_root\\ProfessionalProject\\trunk\\Professional\\FinalOutput\\Release\\Professional.exe
You may stop collection manually. The processes listed above will be terminated.
Collection time: 38s
Warning: Cannot load data file `D:\\prof_tfs_root\\ProfessionalProject\\trunk\\Professional\\Chart\\My Advisor Results - Professional\\survey\\data.0\\2368-2664.0.trace' (Data file is corrupted).
Finalizing the result took 0.161 seconds.
Its a 32-bit C++ app/release or debug build (error happens with both), with generated debug info and debug info format /Zi.
Nqueens sample works w-out problem on my machine (admin user, VS 2010 Premium with installed x64 compiler tools, 64-bit processor, Windows 7).
Thanks in advance for your assistance !
Aleksandar
Peter_W_Intel
Now there is a new update 1 available for Intel Parallel Advisor.
Is it possible that you can try test application on new build?
If the problem persists on, please go to https://premier.intel.com to submit this issue with test application. Thank you!
Regards, Peter
Peter_W_Intel
Regards, Peter
acolovic
Update 1 solved the problem. Tnx!
Keep up good work with this great tool ...
Aleksandar
