Software Archive
Read-only legacy content
17060 Discussions
Amberlake build support
Jon-xelex
I followed the instructions from the following webpage to build the KabylakeRvp3 board successfully with this command
python build_bios.py -p KabylakeRvp3
edk2-platforms/Readme.md at master · tianocore/edk2-platforms · GitHub
I tried to build the package with the AmberLake FSP by this command
build -a IA32 -a X64 -n 5 -t VS2015x86 -b DEBUG -p KabylakeOpenBoardPkg\KabylakeRvp3\OpenBoardPkg.dsc -y Kaby.report
but saw some error messages as shown below
generating FVLATESILICON FV
Generate Region at Offset 0x190000
Region Size = 0x1E0000
Region Name = FV
Generating FVUEFIBOOT FV
Generating FVUEFIBOOTUNCOMPACT FV
Generate Region at Offset 0x370000
Region Size = 0x180000
Region Name = FV
Generating FVPOSTMEMORY FV
Generating FVPOSTMEMORYUNCOMPACT FV
Generate Region at Offset 0x4F0000
Region Size = 0xA0000
Region Name = FV
Generating FVMICROCODE FV
Generate Region at Offset 0x590000
Region Size = 0x60000
build.py...
: error 000E: File/directory not found in workspace
c:\minnow\AmberLakeFspBinPkg/Fsp_Rebased_S.fd
build.py...
: error 7000: Failed to execute command
- Failed -
Build end time: 21:45:03, Jul.12 2020
Build total time: 00:02:51
Could you help to give me some suggestions to make progresses?
Sincerely,
Jon
Jon-xelex
It appears, for some reason, the FSP directory is not correct.
It is supposed to be at
c:\minnow\FSP\AmberLakeFspBinPkg/Fsp_Rebased_S.fd
instead of
I already have C:\minnow\FSM in my PACKAGES_PATH
Could you give me some suggestions to try?
Jon
