Software Archive
Read-only legacy content
17060 Discussions
Android Build Error - XDK 3759
Ernani_Torquato
Hello, after upgrading to the latest version 3759 I can not compile my project.
Attached to the log, I appreciate any help.
Some details:
Cordova CLI 6.2.0
Minimum Android API: 15
Targed Android API: 22
Crosswalk: 19
Ernani_Torquato
Hello, the removal of the plugin was unsuccessful.
The solution found was to recreate the project, add the plugins and copy the www folder to the new project.
Thanks for the sugestion.
PaulF_IntelCorp
I think the problem is due to the diagnostic plugin you've added, which requires Android API 23 and is likely the cause of this build failure. Try removing it to see if it builds without that plugin.
Ernani_Torquato
