Software Archive
Read-only legacy content
17060 Discussions
Android Build Error
Sourabh_A_
I am building an HTML 5 based android app using cordova
I have set the target sdk to 19, but while building it is using the android build tool 25 and build fails.
PaulF_IntelCorp
Sourabh -- the target SDK is the level at which your app is expected to be tested against or compatible with, it does not specify the version of the SDK that is used for the build. Instead, it affects the behavior of the "compatibility layers" on the device when your app is actually loaded and run on an Android device.
Because the build system is in the cloud, you do not have control over the specific SDK that is used to actually build your app. If you need that level of control you need to use Cordova CLI directly.
My guess is this has something to do with the "diagnostics" plugin you are including. It is likely forcing a specific SDK version number. Try removing it from the project and building again to see if that eliminates the build error.
