Software Archive
Read-only legacy content
17060 Discussions
Android Build Failed. XDK 2611
Joaquín_P_
I don't know what's going on. 2 days before I could compile correctly and flawless. Now I don't.
Any ideas? More info below
Calling plugman.fetch on plugin ".../cachedPlugins.6XZYDO.tmp/cache.o1tZPs.pl/org.apache.cordova.device"
Copying plugin ".../cachedPlugins.6XZYDO.tmp/cache.o1tZPs.pl/org.apache.cordova.device" => ".../DreamLand/plugins/org.apache.cordova.device"
Calling plugman.install on plugin ".../DreamLand/plugins/org.apache.cordova.device" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.device" for android
Install start for "org.apache.cordova.device" on android.
path does not exist: .../DreamLand/platforms/android/src/org/apache/cordova/device
Beginning processing of action stack for android project...
Parsing android project files...
Action stack processing complete.
Running command: .../DreamLand/platforms/android/cordova/version
Command finished with error code 0: .../DreamLand/platforms/android/cordova/version
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'org.apache.cordova.device' ]
Writing out cordova_plugins.js...
Install complete for org.apache.cordova.device on android.
Calling plugman.fetch on plugin ".../cachedPlugins.6XZYDO.tmp/cache.dFBWh4.pl/org.apache.cordova.splashscreen"
Copying plugin ".../cachedPlugins.6XZYDO.tmp/cache.dFBWh4.pl/org.apache.cordova.splashscreen" => ".../DreamLand/plugins/org.apache.cordova.splashscreen"
Calling plugman.install on plugin ".../DreamLand/plugins/org.apache.cordova.splashscreen" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.splashscreen" for android
Install start for "org.apache.cordova.splashscreen" on android.
path does not exist: .../DreamLand/platforms/android/src/org/apache/cordova/splashscreen
Iterating over installed plugins: [ 'org.apache.cordova.device',
  'org.apache.cordova.splashscreen' ]
Install complete for org.apache.cordova.splashscreen on android.
Generating config.xml from defaults for platform "android"
Calling plugman.prepare for platform "android"
Wrote out Android application name to "DreamLand"
This app does not have launcher icons defined
Wrote out Android package name to "com.horiugames.dreamland"
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../DreamLand]
Will process and update the following config files:
    Config.xml = [.../DreamLand/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [DreamLand]
Updating full app name to [DreamLand]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [19]
Processing preference android-installLocation [auto]
Processing preference permissions
Updating the versionCode
Updating the versionName
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../DreamLand/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../DreamLand/platforms/android/cordova/build --release
Buildfile: .../DreamLand/platforms/android/build.xml
-set-mode-check:
-set-release-mode:
-release-obfuscation-check:
     [echo] proguard.config is ${proguard.config}
-pre-build:
-check-env:
 [checkenv] Android SDK Tools Revision 24.3.3
 [checkenv] Installed at /Developer/android-sdk-linux
-setup:
     [echo] Project Name: CordovaApp
  [gettype] Project Type: Application
-build-setup:
[getbuildtools] Using latest Build Tools: 22.0.1
     [echo] Resolving Build Target for CordovaApp...
[gettarget] Project Target:   Android 4.4.2
[gettarget] API level:        19
     [echo] ----------
     [echo] Creating output directories if needed...
    [mkdir] Created dir: .../DreamLand/platforms/android/ant-build
    [mkdir] Created dir: .../DreamLand/platforms/android/ant-build/res
    [mkdir] Created dir: .../DreamLand/platforms/android/ant-build/rsObj
    [mkdir] Created dir: .../DreamLand/platforms/android/ant-build/rsLibs
    [mkdir] Created dir: .../DreamLand/platforms/android/ant-gen
    [mkdir] Created dir: .../DreamLand/platforms/android/ant-build/classes
    [mkdir] Created dir: .../DreamLand/platforms/android/ant-build/dexedLibs
     [echo] ----------
     [echo] Resolving Dependencies for CordovaApp...
[dependency] Library dependencies:
[dependency]
[dependency] ------------------
[dependency] Ordered libraries:
[dependency]
     [echo] ----------
     [echo] Building Libraries with 'release'...
nodeps:
-set-mode-check:
-set-release-mode:
-pre-build:
-check-env:
-setup:
  [gettype] Project Type: Android Library
-build-setup:
     [echo] ----------
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/res
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/libs
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/ant-build
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/ant-build/res
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/ant-build/rsObj
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/ant-build/rsLibs
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/ant-gen
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/ant-build/classes
    [mkdir] Created dir: .../DreamLand/platforms/android/CordovaLib/ant-build/dexedLibs
     [echo] ----------
[dependency] No Libraries
[dependency]
-code-gen:
[mergemanifest] Merging AndroidManifest files into one.
[mergemanifest] Manifest merger disabled. Using project manifest only.
     [echo] Handling aidl files...
     [aidl] No AIDL files to compile.
     [echo] ----------
     [echo] Handling RenderScript files...
     [echo] ----------
     [echo] Handling Resources...
     [aapt] Generating resource IDs...
     [echo] ----------
     [echo] Handling BuildConfig class...
[buildconfig] Generating BuildConfig class.
-pre-compile:
-compile:
    [javac] Compiling 93 source files to .../DreamLand/platforms/android/CordovaLib/ant-build/classes
    [javac] Note: Some input files use or override a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
     [echo] Creating library output jar file...
      [jar] Building jar: .../DreamLand/platforms/android/CordovaLib/ant-build/classes.jar
-post-compile:
-obfuscate:
-dex:
     [echo] Library project: do not convert bytecode...
-crunch:
   [crunch] Crunching PNG Files in source dir: .../DreamLand/platforms/android/CordovaLib/res
   [crunch] To destination dir: .../DreamLand/platforms/android/CordovaLib/ant-build/res
   [crunch] Crunched 0 PNG files to update cache
-package-resources:
     [echo] Library project: do not package resources...
-package:
     [echo] Library project: do not package apk...
-post-package:
-release-prompt-for-password:
-release-nosign:
     [echo]
[propertyfile] Creating new property file: .../DreamLand/platforms/android/CordovaLib/ant-build/build.prop
[propertyfile] Updating property file: .../DreamLand/platforms/android/CordovaLib/ant-build/build.prop
-release-sign:
-post-build:
release:
-code-gen:
     [echo] ----------
     [echo] ----------
     [echo] ----------
-pre-compile:
     [echo] Set jars path to: .../DreamLand/platforms/android/CordovaLib/ant-build/classes.jar
-compile:
    [javac] Compiling 5 source files to .../DreamLand/platforms/android/ant-build/classes
-post-compile:
-obfuscate:
-dex:
      [dex] input: .../DreamLand/platforms/android/ant-build/classes
      [dex] input: .../DreamLand/platforms/android/CordovaLib/ant-build/classes.jar
      [dex] Pre-Dexing .../DreamLand/platforms/android/CordovaLib/ant-build/classes.jar -> classes-669caf18be207201961905ba03c7de0d.jar
      [dex] Converting compiled files and external libraries into .../DreamLand/platforms/android/ant-build/classes.dex...
       [dx] Merged dex A (9 defs/5.0KiB) with dex B (209 defs/317.2KiB). Result is 218 defs/392.3KiB. Took 0.3s
-crunch:
   [crunch] Crunching PNG Files in source dir: .../DreamLand/platforms/android/res
   [crunch] To destination dir: .../DreamLand/platforms/android/ant-build/res
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-hdpi/icon.png => .../DreamLand/platforms/android/ant-build/res/drawable-hdpi/icon.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-hdpi/icon.png: 67% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-land-hdpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-land-hdpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-land-hdpi/screen.png: 97% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-land-ldpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-land-ldpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-land-ldpi/screen.png: 96% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-land-mdpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-land-mdpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-land-mdpi/screen.png: 97% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-land-xhdpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-land-xhdpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-land-xhdpi/screen.png: 99% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-ldpi/icon.png => .../DreamLand/platforms/android/ant-build/res/drawable-ldpi/icon.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-ldpi/icon.png: 0% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-mdpi/icon.png => .../DreamLand/platforms/android/ant-build/res/drawable-mdpi/icon.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-mdpi/icon.png: 0% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-port-hdpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-port-hdpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-port-hdpi/screen.png: 97% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-port-ldpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-port-ldpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-port-ldpi/screen.png: 97% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-port-mdpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-port-mdpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-port-mdpi/screen.png: 99% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-port-xhdpi/screen.png => .../DreamLand/platforms/android/ant-build/res/drawable-port-xhdpi/screen.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-port-xhdpi/screen.png: 99% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable-xhdpi/icon.png => .../DreamLand/platforms/android/ant-build/res/drawable-xhdpi/icon.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable-xhdpi/icon.png: 53% size of source)
   [crunch] Processing image to cache: .../DreamLand/platforms/android/res/drawable/icon.png => .../DreamLand/platforms/android/ant-build/res/drawable/icon.png
   [crunch]   (processed image to cache entry .../DreamLand/platforms/android/ant-build/res/drawable/icon.png: 53% size of source)
   [crunch] Crunched 13 PNG files to update cache
-package-resources:
     [aapt] Creating full resource package...
     [aapt] .../DreamLand/platforms/android/assets/www/images/monta??aprimerplanoverderetocado-sheet0.png: error: Invalid filename.  Unable to add.
BUILD FAILED
/Developer/android-sdk-linux/tools/ant/build.xml:928: The following error occurred while executing this line:
/Developer/android-sdk-linux/tools/ant/build.xml:946: null returned: 1
Total time: 25 seconds
.../DreamLand/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: ant with args: release,-f,.../DreamLand/platforms/android/build.xml,-Dout.dir=ant-build,-Dgen.absolute.dir=ant-gen
Command finished with error code 8: .../DreamLand/platforms/android/cordova/build --release
Error: .../DreamLand/platforms/android/cordova/build: Command failed with exit code 8
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
Dale_S_Intel
Well, it looks like it's failing when trying to build one of the plugins.  I have seen some problems like this when trying to use a plugin for Cordova 5 on Cordova 4.  There were significant changes between them.
First, I'd find out which plugin is causing the fail.
Then I'd double check the version and see if it's compatible with CLI 4 or 5.
You might need to get an older version of the plugin or build with Cordova 5, if that's feasible.
What plugins are you using?
Dale
Pamela_H_Intel
The error message states that your monta??aprimerplanoverderetocado-sheet0.png has an invalid filename.
It has two '?'s - that probably is not what you named the file. What character are you using there?
Joaquín_P_
Thank you both for the answer. The problem was indeed the strange character in my filename. I don't speak english, my languague it's spanish so the filename contained "ñ" for "mountain" (montaña).
Sorry for the late reply and thanks once more for your help.
