Software Archive
Read-only legacy content
17060 Discussions
Android Build refuses to install
Elie_A_
I work on the last version of Intel XDK under Cordova 5.1.1. Debugging is working on IOS and Android. IOS Build works but Android Build refuses to install. When I try to install it on device it says Version: N/A, Name: N/A, Package name: N/A (of course all these informations exist on intel XDK)
If someone can help me - Thank you
John_H_Intel2
How are you trying to install? ADB tools or via the email link?
What do the settings look for this app?
What is the OS of the device?
Elie_A_
Thank you for your answer:
To install I just loaded the build created by XDK in my computer and then I copied it in my android device. After I use ES Explorateur to find the apk file and install it.
The OS of the device is : Android 4.4.4
the setting are :
Description: Missions System for Tzivos Hashem
author: Tzivos Hashem
<access origin="*" launch-external="yes"/>
Plugins:
cordova-plugin-splashscreen version="2.1.0"
cordova-plugin-inappbrowser version="1.0.1"
intelxdk:value="intel.xdk.cache :version="1.2.2"
intelxdk:value="intel.xdk.file :version="1.2.2"
intel.xdk.camera version="1.2.3"
cordova-plugin-legacy-whitelist" :version="1.1.0"
"android-minSdkVersion" value="14"
"android-targetSdkVersion" value="21"
"android-installLocation" value="auto"/>
"Fullscreen" value="false"/>
"android-signed" value="true"/>
"splashscreen" value="splash"/>
Elie_A_
IMPORTANT :
under Cordova 4.1.2 (with plugins associated) it works
Under Cordova 5.1.1 it doesn't work
