Software Archive
Read-only legacy content
17060 Discussions
Android Device Emulator - Intel x86 Atom - Force GPU Rendering Issue
SergeyKostrov
Valued Contributor II
This is a feedback for Intel x86 Atom System Image for Android 4.0.3 (API 15) package:
There is inconsistency with configuration settings related to'Force GPU rendering' option. Why did you
assume that Android Virtual Device has a GPU? Why did you allow to enable 'Force GPU Rendering' when
'GPU emulation' is not selected in a supported 'Hardware' list? Please take a look at:
Settings -> Developer options -> Force GPU Rendering
A screenshot is enclosed:
Alexander_W_Intel
Sergey,
You see this behaviour because there runs an unmodified version of Android inside the emulator. That means that you have the same options as on a real device. If the hardware is emulated without GPU acceleration (your option on the screenshot) than I would assume that the option is simply not changing anything.
If you think that behaviour should be changed, here is the Android* Bugtracker from Google:http://code.google.com/p/android/issues/list
Alex
Alexander_W_Intel
Sergey,
Alex
SergeyKostrov
...here is the Android* Bugtracker from Google:http://code.google.com/p/android/issues/list
Thank you, Alexander. I'll take a look.
