Software Archive
Read-only legacy content
Android build failed
Hooman_F_1
Running XDK version 1995.  iOS build succeeds but Android fails.  I have tried signing/unsignging, but no difference.  I also have a 3rd party plugin and tried it with and without and it made no difference. This is all that's displayed:
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
  • Building a Cordova 4.1.2 application.
  • The application name is "Bluetooth sample"
  • The package name is "com.newgr.gwst"
  • Preference android-signed set to true. Application will be signed.
Pavel_I_
I have the same issue, when building the project Yesterday all was fine, today getting this error:
The build failed. An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
Building a Cordova 3.5 application.
The application name is "Applied Streetview"
The package name is "com.applied_streetview.tracker"
Greg_T_1
Same issue here. My last successful build was about an hour ago. For me nothing in my project settings changed. Just updated some application code.
Gerrit_M_
Hello all,
Same here, no android build and nothing changed in my code, but it did not build. However i can build crosswalk apps for android
Even for testing; i just put the simple buttons example, that was provided with the intel Xdk (version 1995) software and that one also failed to build. So i hope to get a solution on this one.
Greetings Gerrit
Andre_Marques_P_
Some problem to me...
Thomas_R_1
Same here. Happened 8 hours ago.
Can build iOS, Crosswalk without any problems. Can't build Cordova Android.
Mohamed_D_
I am experiencing exactly the same problem all day ...I haven't changed any plugins I even tried to build some simple sample apps still I get the same errors I am running intel xdk version 1995 but I don't think the problem with the version because just before updating from 1912 I had the same problem.
Here's the log i keep  getting
anybody found any solution yet
The build failed.
Build Log:
  • The application name is "Salat24/7lite"
  • The package name is "xdk.intel.salat.lite"
Naveen_V_
Android build failed error.
android build fail... No problem for "Crosswalk android build". it creates output without any problem...
The build failed.
Build Log:
  • The application name is "inadmob"
  • The package name is "com.infocom.inadmob"
Ekaterina_Latukhina
Hi everyone,
we have the same problem with all our projects since yesterday:
The build failed.
Build Log:
    The application name is "MobVision"
    The package name is "xdk.intel.mobvision.projectq"
Version of Intel XDK is 1912, but i can't update, it always failed too.
I think it is the server problem and I hope they will fix it for a short time. My students are preparing diploma projects. We really need it as soon as possible, please do it! =)
Mour_D_
same error with me also i don't know why pls help
Antonio_R_2
The same problem. This is very serious.
I hope see this problem fixed!
Naveen_V_
still this problem stands. how to solve this issue. this is really a big problem.
John_H_Intel2
There was an issue which has been fixed. Sorry for the delay in getting this resolved.
Hooman_F_1
It's working for me as well now.
My 2c: this is the kind of issue that makes the dev community not take XDK seriously.  If Intel is serious about this platform, it needs to run it like Amazon and Microsoft.
Naveen_V_
Thanks for fixing the issue. now it's works really well as before. thank you :)
Roman_M_
OMG, same issue right now.
PaulF_IntelCorp
Are you having trouble with an Android or a Crosswalk build?
Roman_M_
Crosswalk.
PaulF_IntelCorp
The build system was updated this afternoon to address some issues. Please try it again to see if you still have the same problem.
Roman_M_
It's working for me as well now. Thanks!
Nicolas_Z_
Today again the issue is present!
