Software Archive
Read-only legacy content
17060 Discussions
Android build failing
Douglas_Biazioli
Hello!
I'm running XDK 1995 and can't build my project to Android anymore. I think it's not a project error, because iOS builds are fine.
Anyone having the same issue?
PaulF_IntelCorp
@Douglas -- According to the error.log you provided, I see you are including the following plugins:
Iterating over installed plugins: [
  'org.apache.cordova.device',
  'org.apache.cordova.splashscreen',
  'org.apache.cordova.inappbrowser',
  'org.apache.cordova.dialogs',
  'com.connectivity.monitor',
  'com.admob.google',
  'org.apache.cordova.network-information',
  'org.apache.cordova.statusbar',
  'com.google.play.services' ]
There were some troubles yesterday with some builds that were including an admob plugin (there are more than one of them) that caused the build system to consume very large amounts of disk space. Yours could have been the one that caused that. What happens if you remove the admob plugin? Does the build work then?
@Gary, I'm not seeing any clues... Can you attach the full error.log? (Please do not past it into a thread, it is very difficult to scan that way.)
Amrita_C_Intel
Can you please send the zip file of your code? Because I tested it and it is working for me.
Gary_H_2
Some of my Android project crosswalk builds have also started failing but other smaller projects still build. I verified my assets and I tried again but no luck.
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
  • The App ID is "com.mainstreamdata.wispeodroid"
  • The App Name is "Wispeo"
  • Crosswalk Version: 10.39.235.15
  • Plugin "org.apache.cordova.device" (0.2.5) installed.
  • Plugin "org.apache.cordova.splashscreen" (0.2.5) installed.
  • Plugin "org.apache.cordova.statusbar" (0.1.9) installed.
  • Plugin "org.apache.cordova.contacts" (0.2.16) installed.
  • Plugin "org.apache.cordova.file" (1.3.3) installed.
  • Plugin "org.apache.cordova.file-transfer" (0.4.8) installed.
  • Plugin "cordova-plugin-network-information" (1.0.2-dev) installed.
  • Plugin "com.ionic.keyboard" (1.0.4) installed.
  • Plugin "nl.x-services.plugins.launchmyapp" (3.2.2) installed.
PaulF_IntelCorp
  'com.admob.google',
Gary_H_2
Where do I get the error log from? What I pasted was all i got.
Douglas_Biazioli
@Paul the problem was the plugin, I'm using this one now: https://github.com/floatinghotpot/cordova-plugin-admob
And it's working fine. Thank you for your help!
@Gary
You can see a link to the log i1n the "Build Failed" page.
Gary_H_2
There is no link that i can see.
PaulF_IntelCorp
@Gary -- the summary build log is what you pasted. There is also a detailed build log in a blue link. See this doc page: https://software.intel.com/en-us/xdk/docs/using-the-build-tab#buildcordovaapps
Gary_H_2
No link on the page i get.
PaulF_IntelCorp
Gary -- can you successfully build a blank template or simple sample app? If so, go back to your app and start by removing plugins, one-by-one, until you find the one that is causing the problem (usually they are the suspect).
