Software Archive
Read-only legacy content
17060 Discussions
Android random function
JLuna5
I'm learning  to developer on android, and I'm making a exercise of Sharedpreferences, but I don't know how to generate a random number and show into textview on my app.
JLuna5
Estoy aprendiendo a desarrolladores en Android, y estoy haciendo un ejercicio de Sharedpreferences, pero no sé cómo generar un número aleatorio y mostrar en TextView en mi aplicación.
Bernard
Valued Contributor I
Hi JudLup
Sadly I do not know Android platform,but Android is written in Java and probably has built in math library.I would also recommend you to check posibility of importing Java classes.
SergeyKostrov
Valued Contributor II
>>... I don't know how to generate a random number... Here is example: ... class TestSet { ... TestSet() { float r = ( ( float ) Math.random() - 0.5f ) * 0.2f; ... } ... }
Mohamed_helmi_b_
you can use "math.random". this methode generate a number between 0 and 1. you can multlply it with the max number that you want to reach.
Mohamed_Ali_A_
Here are some examples with results :
Math.random()
Math.round(Math.random()*10); // 1 digit random
Math.round(Math.random()*100); //2 digit random
Math.round(Math.random()*1000); //3 digit random
Results:
Math random value :0.8393086905318781
Math random value :3
Math random value :82
Math random value :719
Ahmed_BH
Hi JudLup Luna,
try this example code it can help you
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<TextView
android:layout_height="wrap_content"
android:text="@string/hello"
<Button
android:text="Generate Random number"
android:id="@+id/generate"
<TextView
android:id="@+id/generatenumber"
</LinearLayout>
RandomNumber.java
import java.util.Random;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.TextView;
public class RandomNumber extends Activity {
/** Called when the activity is first created. */
             @Override
             public void onCreate(Bundle savedInstanceState) {
                        super.onCreate(savedInstanceState);
                        setContentView(R.layout.main);
                        final Random myRandom = new Random();
                        Button buttonGenerate = (Button)findViewById(R.id.generate);
                        final TextView textGenerateNumber = (TextView)findViewById(R.id.generatenumber);
                        buttonGenerate.setOnClickListener(new OnClickListener(){
                                 @Override
                                 public void onClick(View v) {
                                      // TODO Auto-generated method stub
                                      textGenerateNumber.setText(String.valueOf(myRandom.nextInt()));
JLuna5
Hi iliyapolak, thank you for you suggestion.
JLuna5
Hi Sergey Kostrov, Thank you for you suggestion.
JLuna5
Sergey Kostrov thank you!
JLuna5
Mohamed Ali A. thank you!
JLuna5
HI Ahmed BH , thank you for you answer, this is very complete.
Ashwin_S_Ashok
there are random function class in java..
random r= new random();
Ashwin_S_Ashok
Random random = new Random();
int ran=random.nextInt(100);
here is the code..
Raghavendr_U_Intel
to an extent you will have to bank on Java capabilities. I saw some examples which you can use for Random number generation. Other answers here in this thread is also very valid.
http://www.javapractices.com/topic/TopicAction.do?Id=62
