Software Archive
Read-only legacy content
17060 Discussions
Angular JS Support for UI
Francesco_I_
Hi
I start to develop an app that access to a web service end to content stored in a web site.
I'd like to use Angular JS as framework, this framework is supported in Intel SDK?
there may be problems in the integration of the user interface with Agular?
thank so much
Swati_S_Intel1
AngularJS is supported by XDK. See this document for details:
https://software.intel.com/en-us/html5/articles/angular-and-the-intel-xdk
and here is a sample starter project using ionic and AngularJS.
https://github.com/krisrak/ionic-angularjs-intelxdk-seed
Swati
Francesco_I_
hi
thanks for your reply.
I tested what you have suggested and the first link work fine. Can I use the "app_framework" as framework for UI ? because Ionic is only beta!
app_framework and Angular JS work well together??
I noticed that when I copied a component in the user interface development environment I deleted everything I had created before.
I fear that they are perfectly compatible.
br
