Software Archive
Read-only legacy content
Animation
bob_johnson
I am tring to animate graphics. When I run my program it executes the code but only the last frame shows up. There is a delay which I assume is because it is "drawing" the frames. So I must not be doing something that will update the window for each frame.
Here is a portion of my code that does the animation. The routine gtest does the actual drawing of the frame.
case (IDM_GRAPH_CYCLE)
do i=1,nhours
pdate = dates1(nhours)
ptime = times1(nhours)
newdata = .true.
call gtest (hWnd)
retlog = UpdateWindow(hWnd)
call sleep(100)
enddo
ret = InvalidateRect (hWnd, NULL_RECT, .TRUE.)
MainWndProc = 0
return
bob_johnson
OK here is the code again. I hope it comes out better.
	do i=1,nhours
		newdata = .true.
		call gtest (hWnd)
		call sleep(100)
	enddo
                MainWndProc = 0
                return
Jugoslav_Dujic
Valued Contributor II
It's almost good -- you should move InvalidateRect before UpdateWindow; UpdateWindow updates only if there's something to update -- you have to tell what it is with InvalildateRect.
bob_johnson
Jugoslav,
That worked great !! It is now cycling through the frames. However it is not smooth. It shows each frame as it is drawn. Do I need to do some sort of double buffering ? If so how do I do that. Thanks
Jugoslav_Dujic
Double-buffering improves the animation, surely. You should use:
hBufferDC = CreateCompatibleDC(hWindowDC, iWidth, iHeight)
hBmp = CreateCompatibleBitmap(hWindowDC)
iSt = SelectObject(hBufferDC, hBmp)
to create buffer DC. Your WM_PAINT handler should have, apart from
BeginPaint/EndPaint, only:
hDC = BeginPaint(hWnd, ps)
iSt = BitBlt(hDC, ps%rcPaint%Left, ps%RcPaint%Top,  &
ps%rcPaint%Right-ps%rcPaint%Left, ps%rcPaint%Bottom-ps%rcPaint%Top, &
hBufferDC, ps%rcPaint%Left, ps%rcPaint%Top,SRCCOPY)
Always draw on hBufferDC and you can do it whenever you need update (not on WM_PAINT). Only ensure that you call InvalidateRect when you do the drawing.
Of course, take care that of proper creation/destruction (DeleteDC) of hBufferDC -- usually, you create it only once and destroy it at program end.
HTH
Jugoslav
