Software Archive
Read-only legacy content
17060 Discussions
Annotations confusing
michael-a-carr
Here is a line from my source code listing:
3 5 6 7 geom%e%L = ABS(geom%e)
Here are the corresponding annotations:
3. Not unrolling loop: unroll inhibitor
5. Unrolling loop 7 times
6. Prefetching unnamed variable, 44 bytes ahead
7. Prefetching .T34_, 32 bytes ahead
So it is not unrolling but it is unrolling 7 times? I don't understand that...
also, there are 8 annotations in total but the source listing only references 7 annotations. Is there a numbering problem between the source listing and the annotations? This might explain both problems...
Annotations are often cryptic, I'll agree. They're there more to help understand when something wasn't optimized in a particular way, rather than as a general informational tool. I'm guessing in your case that there are two loops, because of potential overlaps, and you get two annotations. The optimizer probably fused the loops.
I suggest reading annotations for entertainment value, unless you really want to wade in deeply.
Steve
