Software Archive
Read-only legacy content
17060 Discussions
Anyone "Loosing App Designer" in a project?
Rob_H_1
I'm loosing the app designer in projects HTML+ Corova & App framework 3
I've tried safe restart and normal, but the app designer just disappears. Any idea how to get it back?
Diego_Calp
Valued Contributor I
Happened to me some time ago.
Try opening manually index.html for that project in Brackets editor.
Diego
Chris_P_Intel
Rob,
What do you mean by "losing the app designer" ? Do you mean that the Code | Design button is gone?  If so, are you sure its the project you had before? If you make a new project and do not click the "App Designer" checkbox, then you'll never be offered the Code | Design button
Chris
Rob_H_1
Chris, yes it's as if you started a project without the designer. The button goes away. Project definatly had it.
Chris_P_Intel
Do you have the latest (v3088) ?
Rob_H_1
Chris, yes I do. Have also had it happen on early release.. which updated yesterdsy.
Chris_P_Intel
Can you .zip up and send the project? Sounds like something happened to the .xdk or .xdke file
Rob_H_1
Sure, i should still have some of them. I should also have projects where the designer is available but the go button went missing as well.
Hava_C_
This is happening to me even when opening a demo project.
Chris_P_Intel
Can you .zip up and send a project where this has happened?
