Software Archive
Read-only legacy content
App preview problems
sinisa_k_
I'w installed XDK on my PC (no firewalls whatsoever).
I have app preview on iphone and on android tablet. All devices are wifi connected to my router and can access internet but both fail to see anything under their local apps tab ("can not find intel xdk error") and both devices see projects under server apps tab but only apple can open and play projects while android tablet gets error "unable to retrieve app from the cloud server".
How can i enable local wifi preview to work and why is android fail to open projects wich apple opens?
Thank you!
sinisa_k_
Thank you who ever post this but this is not the issue becouse after fresh instalation android device managed to open server apps and i know for a fact that it forks but at some point it faild and now its impossible to open any project.
PaulF_IntelCorp
Did you follow these instructions? https://software.intel.com/en-us/xdk/docs/using-the-test-tab
Note the Mobile/WIFI button must be set to WIFI to use App Preview locally with the XDK. Also, be sure they are on the same subnet, ideally on the same switch; there are some very inexpensive switches that do not pass through the traffic required to make the local WIFI mode work.
sinisa_k_
@Paul Fischer (Intel)
sinisa_k_
update...
iw made uninstall and clean renstall ano now all works, even wifi. What went wrong... who knows, but now all is ok.
one question still remains... how can i delete projects from cloud server?
thank you!
Jose_Manuel_G_
Hi Sinisa!
You can delete projects from the cloud server in this url:
https://appcenter.html5tools-software.intel.com/csd/cloud-services-dashboard-login.aspx?ReturnUrl=%2f
You have to login and then you can see all the projects you have in the cloud under the "Control center" tab.
Jose
sinisa_k_
Can someone help me... that URL is not working for me any more.
i only receive following message:
Thank you for using the Intel® XDK.
If you are accessing this service from AppPreview, you may close the sign in window.
PaulF_IntelCorp
See the FAQ #Q29 on this page https://software.intel.com/en-us/xdk/faqs/general
