Software Archive
Read-only legacy content
17060 Discussions
Application can't build a second time
Yuri_W_
Hi.
I built a game app on Intel XDK: Crosswalk for Android and it completely worked the first time. Later on, I edited the app in my original software and tried to build it again on Intel XDK, but it gave me this error:
"The Build failed. An error occured while building the application. Verify your build assets are correct and try again."
I double-checked and they are pretty much the same 'build assets' I used in the first one that was successful. I do not know why it's giving me this error.
Help, please.
Hamilton_Tenório_da_
Valued Contributor I
You can try to build later. Sometimes the server became instable.
John_H_Intel2
Can you build different app of the same platform?
Yuri_W_
I created a blank project, entered correct build details, yet it still doesn't build. Is this a problem in the software itself?
Yuri_W_
Do I just re-install Intel XDK?
Swati_S_Intel1
Can you try building without uploading any assets - i.e. launch icons and splash screens and see if it works. Then add assets one by one. Try with one of the sample apps. If that doesn't work please re-install XDK.
Swati
Amrita_C_Intel
 Did you try to restart intel xdk? Whenever I had that error it had been solved by doing that.
Can you try building with Android instead of android crosswalk? Sometimes it works. Meanwhile we will investigate.
Yuri_W_
Apparently, the problem was with my 'App ID' name. Solved that and it's working again.
