Software Archive
Read-only legacy content
17060 Discussions
Apply _CIlk_shared to static and local variables
Shanci_G_
Hi everyone:
I learn from the official document that _Cilk_shared cannot be applied to static variables and variables local to a function.
I've done some experiments with a demo. Here is my code:
#pragma offload_attribute (push, _Cilk_shared)
#include <offload.h>
#pragma offload_attribute (pop)
#include <stdio.h>
struct mic_int {
	int p;
_Cilk_shared int test_result(_Cilk_shared struct mic_int * v) {
	int result = v->p + 3;
	return result;
// static _Cilk_shared struct mic_int * _Cilk_shared v;
// static _Cilk_shared struct mic_int * v;
int main() {
	// _Cilk_shared struct mic_int * v;
	// _Cilk_shared struct mic_int * _Cilk_shared v;
	int result = 0; // Use placement new to construct an object in the shared memory space.
	v = (_Cilk_shared struct mic_int*)_Offload_shared_malloc(sizeof(struct mic_int));
	v->p = 6;
	result = _Cilk_offload test_result(v);
	//int threads_number = __cilkrts_get_nworkers();
	//printf("the threads number is %d\n", threads_number);
	if (result != 9)
		printf("Failed\n");
	else
		printf("Passed\n");
	_Offload_shared_free(v);
	return 0;
The test results:
  1. static document shared pointer, compiler warning as "_Cilk_shared may not be applied to static variables", but the test has been passed;
  2. static document non-shared pointer to shared VM, no compiler warning and test passed;
  3. local non-shared pointer to shared VM, no compiler warning and test passed;
  4. local shared pointer, compiler warning as "_Cilk_shared may not be applied to local variables", but the test has been passed;
  5. local static shared pointer, compiler warning as "_Cilk_shared may not be applied to local variables", and the test failed, there is a segment fault!
Is there explanation about the official document and my demo results? The map of shared VM is a little confusing for me.
yzgsc123
