Software Archive
Read-only legacy content
17060 Discussions
Arduino IoTkitSimpleExample on Edison does not appear to send to dashboard
Chandler_H_
Greetings,
I have activated an Intel Edison with Arduino breakout board on the http://dashboard.us.enableiot.com site as well as registered a component with the catalog (ie: temp with temperature.v1.0)
This all works with the Galileo Gen1 with the Gen1 consistently uploading the values to the dashboard successfully.
Steps taken:
I loaded the Arduino IotKitSimpleExampleSendTemp sketch, the sketch appears to go in with a "Done Loading" and "Transfer Complete" like the Gen1 does.
On the Edison
1) issued iotkit-admin intialize
2014-12-15T21:06:45.701Z - info: Token file: /usr/share/iotkit-agent/certs/token.json
2014-12-15T21:06:45.736Z - info: Using data store: /usr/share/iotkit-agent/data/
2014-12-15T21:06:45.742Z - info: Initialized
2) issued iotkit-admin test
root@labgarage:/tmp# iotkit-admin test
2014-12-15T21:06:57.832Z - info: Trying to connect to host ...
2014-12-15T21:06:59.725Z - info: Connected to dashboard.us.enableiot.com
2014-12-15T21:06:59.729Z - info: Environment: prod
2014-12-15T21:06:59.731Z - info: Build: 0.11.2
3) issued iotkit-admin device-id and activate
root@labgarage:/tmp# iotkit-admin device-id
2014-12-15T21:07:19.432Z - info: Device ID: aa-2c-2b-97-14-60
root@labgarage:/tmp# iotkit-admin activate O3FGhqhH
2014-12-15T21:08:19.218Z - info: Activating ...
2014-12-15T21:08:20.506Z - info: Saving device token...
2014-12-15T21:08:20.519Z - info: Sending attributes...
4) issued iotkit-admin register temp temperature.v1.0
root@labgarage:/tmp# iotkit-admin register temp temperature.v1.0
2014-12-15T21:09:18.958Z - info: Starting registration ...
2014-12-15T21:09:19.076Z - info: Sending attributes...
Attributes sent
2014-12-15T21:09:21.912Z - info: Component registered name=temp, type=temperature.v1.0, cid=4cfd2491-f59f-43c6-8fce-95b98c75d845
root@labgarage:/tmp# tail -f agent.log
{"level":"info","message":"Using data store: /usr/share/iotkit-agent/data/","timestamp":"2014-12-15T21:06:45.739Z"}
{"level":"info","message":"Initialized","timestamp":"2014-12-15T21:06:45.743Z"}
{"level":"info","message":"Trying to connect to host ...","timestamp":"2014-12-15T21:06:57.849Z"}
{"level":"info","message":"Connected to dashboard.us.enableiot.com","timestamp":"2014-12-15T21:06:59.727Z"}
{"level":"info","message":"Device ID: aa-2c-2b-97-14-60","timestamp":"2014-12-15T21:07:19.450Z"}
{"level":"info","message":"Activating ...","timestamp":"2014-12-15T21:08:19.235Z"}
{"level":"info","message":"Saving device token...","timestamp":"2014-12-15T21:08:20.508Z"}
{"level":"info","message":"Sending attributes...","timestamp":"2014-12-15T21:08:20.520Z"}
{"level":"info","message":"Starting registration ...","timestamp":"2014-12-15T21:09:18.977Z"}
{"0":{"name":"temp","type":"temperature.v1.0","cid":"4cfd2491-f59f-43c6-8fce-95b98c75d845"},"level":"info","message":"Component registered","timestamp":"2014-12-15T21:09:21.916Z"}
The iotkit-agent never sends the value of "temp".
Thank you for any insight you may be able to provide.
Chandler_H_
A quick add, I was able to send a manual "observation" using the component "temp" to "temperature.v1.0.
root@labgarage:/tmp# iotkit-admin observation temp 110
2014-12-15T21:36:27.263Z - debug: Proxy Connector : rest  to be Set
2014-12-15T21:36:27.303Z - debug: Rest Proxy Created
2014-12-15T21:36:27.553Z - debug: Filename  /usr/share/iotkit-agent/certs/token.json  read  deviceToken=eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJqdGkiOiJmY2NhMjUzMC1jOTNiLTQwMTgtYTQ4Yy0xODZjYzAyMmY1MGQiLCJpc3MiOiJodHRwOi8vZW5hYmxlaW90LmNvbSIsInN1YiI6ImFhLTJjLTJiLTk3LTE0LTYwIiwiZXhwIjoiMjAyNC0xMi0xMlQyMTowODoyMC40MjNaIn0.K8RRVR6MkDc00MDAkLCR-MxTQWt03ggKxeOtqvhJB49kfKJ4KOWhdrC51JB8onJgAFOilHluakqT1Px-0RlyEvaSqoXp0VkmCrO2bfXyp7TtYDIKRAuVfnGE4xs7bgdKV0yKkKtIjKJlMi15MwO4tzrd4hDCDfXPBttLKU8JFwyhHtceNjbUB9ikBptquEtTUuFrJAU214iDIU1PNO-MH3NOWVUDXQocJmwN2MFSs_YnaSwMaU2lAn_-iGjnbTxkX7OP0uLg7ke0qclZ97Awf2Ogg-_KYeLFGUd2qtZDA-duT10g7tdyLBFW3S36OmKxCi2lzBpIbDx5-sPAckmk8w, accountId=4b9ca90a-5cb1-4a35-b14b-f9c261c4cae6
2014-12-15T21:36:27.559Z - debug: Cloud Proxy Created with Cloud Handler  rest
2014-12-15T21:36:27.561Z - debug: Starting Activate Process function
2014-12-15T21:36:27.563Z - debug: The user is:  aa-2c-2b-97-14-60  and password  eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJqdGkiOiJmY2NhMjUzMC1jOTNiLTQwMTgtYTQ4Yy0xODZjYzAyMmY1MGQiLCJpc3MiOiJodHRwOi8vZW5hYmxlaW90LmNvbSIsInN1YiI6ImFhLTJjLTJiLTk3LTE0LTYwIiwiZXhwIjoiMjAyNC0xMi0xMlQyMTowODoyMC40MjNaIn0.K8RRVR6MkDc00MDAkLCR-MxTQWt03ggKxeOtqvhJB49kfKJ4KOWhdrC51JB8onJgAFOilHluakqT1Px-0RlyEvaSqoXp0VkmCrO2bfXyp7TtYDIKRAuVfnGE4xs7bgdKV0yKkKtIjKJlMi15MwO4tzrd4hDCDfXPBttLKU8JFwyhHtceNjbUB9ikBptquEtTUuFrJAU214iDIU1PNO-MH3NOWVUDXQocJmwN2MFSs_YnaSwMaU2lAn_-iGjnbTxkX7OP0uLg7ke0qclZ97Awf2Ogg-_KYeLFGUd2qtZDA-duT10g7tdyLBFW3S36OmKxCi2lzBpIbDx5-sPAckmk8w
2014-12-15T21:36:27.569Z - info: Sending attributes...
2014-12-15T21:36:27.571Z - debug: Attributes Registration :
2014-12-15T21:36:27.572Z - debug: Attributes ,  deviceId=aa-2c-2b-97-14-60, deviceToken=eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJqdGkiOiJmY2NhMjUzMC1jOTNiLTQwMTgtYTQ4Yy0xODZjYzAyMmY1MGQiLCJpc3MiOiJodHRwOi8vZW5hYmxlaW90LmNvbSIsInN1YiI6ImFhLTJjLTJiLTk3LTE0LTYwIiwiZXhwIjoiMjAyNC0xMi0xMlQyMTowODoyMC40MjNaIn0.K8RRVR6MkDc00MDAkLCR-MxTQWt03ggKxeOtqvhJB49kfKJ4KOWhdrC51JB8onJgAFOilHluakqT1Px-0RlyEvaSqoXp0VkmCrO2bfXyp7TtYDIKRAuVfnGE4xs7bgdKV0yKkKtIjKJlMi15MwO4tzrd4hDCDfXPBttLKU8JFwyhHtceNjbUB9ikBptquEtTUuFrJAU214iDIU1PNO-MH3NOWVUDXQocJmwN2MFSs_YnaSwMaU2lAn_-iGjnbTxkX7OP0uLg7ke0qclZ97Awf2Ogg-_KYeLFGUd2qtZDA-duT10g7tdyLBFW3S36OmKxCi2lzBpIbDx5-sPAckmk8w, agent_version=1.5.0, hardware_vendor=Genuine Intel(R) CPU   4000  @  500MHz, hardware_model=linux, Model Name=ia32, Firmware Version=3.10.17-poky-edison+, gatewayId=aa-2c-2b-97-14-60
2014-12-15T21:36:28.963Z - debug: attributes has returned from  rest
2014-12-15T21:36:28.970Z - debug: Filename  /usr/share/iotkit-agent/data/sensor-list.json  read  name=temp, type=temperature.v1.0, cid=4cfd2491-f59f-43c6-8fce-95b98c75d845
2014-12-15T21:36:28.989Z - info: Submitting:  n=temp, v=110
2014-12-15T21:36:28.995Z - debug: Metric doc: {"accountId":"4b9ca90a-5cb1-4a35-b14b-f9c261c4cae6","did":"aa-2c-2b-97-14-60","on":1418679388992,"count":1,"data":[{"on":1418679388992,"value":"110","cid":"4cfd2491-f59f-43c6-8fce-95b98c75d845"}],"gatewayId":"aa-2c-2b-97-14-60","deviceToken":"eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJqdGkiOiJmY2NhMjUzMC1jOTNiLTQwMTgtYTQ4Yy0xODZjYzAyMmY1MGQiLCJpc3MiOiJodHRwOi8vZW5hYmxlaW90LmNvbSIsInN1YiI6ImFhLTJjLTJiLTk3LTE0LTYwIiwiZXhwIjoiMjAyNC0xMi0xMlQyMTowODoyMC40MjNaIn0.K8RRVR6MkDc00MDAkLCR-MxTQWt03ggKxeOtqvhJB49kfKJ4KOWhdrC51JB8onJgAFOilHluakqT1Px-0RlyEvaSqoXp0VkmCrO2bfXyp7TtYDIKRAuVfnGE4xs7bgdKV0yKkKtIjKJlMi15MwO4tzrd4hDCDfXPBttLKU8JFwyhHtceNjbUB9ikBptquEtTUuFrJAU214iDIU1PNO-MH3NOWVUDXQocJmwN2MFSs_YnaSwMaU2lAn_-iGjnbTxkX7OP0uLg7ke0qclZ97Awf2Ogg-_KYeLFGUd2qtZDA-duT10g7tdyLBFW3S36OmKxCi2lzBpIbDx5-sPAckmk8w"}
2014-12-15T21:36:28.998Z - debug: Metric doc: {"accountId":"4b9ca90a-5cb1-4a35-b14b-f9c261c4cae6","did":"aa-2c-2b-97-14-60","on":1418679388992,"count":1,"data":[{"on":1418679388992,"value":"110","cid":"4cfd2491-f59f-43c6-8fce-95b98c75d845"}],"gatewayId":"aa-2c-2b-97-14-60","deviceToken":"eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJqdGkiOiJmY2NhMjUzMC1jOTNiLTQwMTgtYTQ4Yy0xODZjYzAyMmY1MGQiLCJpc3MiOiJodHRwOi8vZW5hYmxlaW90LmNvbSIsInN1YiI6ImFhLTJjLTJiLTk3LTE0LTYwIiwiZXhwIjoiMjAyNC0xMi0xMlQyMTowODoyMC40MjNaIn0.K8RRVR6MkDc00MDAkLCR-MxTQWt03ggKxeOtqvhJB49kfKJ4KOWhdrC51JB8onJgAFOilHluakqT1Px-0RlyEvaSqoXp0VkmCrO2bfXyp7TtYDIKRAuVfnGE4xs7bgdKV0yKkKtIjKJlMi15MwO4tzrd4hDCDfXPBttLKU8JFwyhHtceNjbUB9ikBptquEtTUuFrJAU214iDIU1PNO-MH3NOWVUDXQocJmwN2MFSs_YnaSwMaU2lAn_-iGjnbTxkX7OP0uLg7ke0qclZ97Awf2Ogg-_KYeLFGUd2qtZDA-duT10g7tdyLBFW3S36OmKxCi2lzBpIbDx5-sPAckmk8w"}
2014-12-15T21:36:29.006Z - debug: Metadata Device:  aa-2c-2b-97-14-60 Updated :  agent_version=1.5.0, hardware_vendor=Genuine Intel(R) CPU   4000  @  500MHz, hardware_model=linux, Model Name=ia32, Firmware Version=3.10.17-poky-edison+, created=1418677657734, components=[name=temp, type=temperature.v1.0, cid=4cfd2491-f59f-43c6-8fce-95b98c75d845], deviceId=aa-2c-2b-97-14-60, gatewayId=aa-2c-2b-97-14-60, name=aa-2c-2b-97-14-60, status=active
2014-12-15T21:36:30.123Z - debug: Response From data Submission from API
2014-12-15T21:36:30.126Z - info: Response received:  response=none detail, status=0
2014-12-15T21:36:30.130Z - info: Observation Sent response=none detail, status=0
PeterKerney
It could be that you are using "iotkit-admin register temp temperature.v1.0" and then "iotkit.send("temperature sensor", temp);" so the paramerters don't match. I looked back at your post and noticed you had the parameter correct.
OR
I am not sure is this is exactly your problem or not but I had a similar thing with the Python version at https://github.com/enableiot/iotkit-samples/blob/master/python/IoTkitSimpleExample.py
It tool me a little while (due to lack of good documentation) to realise that the way this all works is that you have an iot-agent that acts as a gateway for the observations from one-many iot-clients. When you look at the IoT solution architecture that we are delivering this makes perfect sense.
As I understand it, when you issue "iotkit-admin observation temp 110", this actually starts up an iot-agent on the localhost on behalf of the command, then sends the observation to the cloud and then shuts down the agent.
Therefore, if you want to send the observation to the cloud, you need the agent running separately and you send the observation to the host that the agent is running on (which may be localhost) as opposed to directly to the cloud.
When I did this with the Python version without the agent running and pointed directly to the cloud, the send observation function failed transparently. When I started the agent in the background and then left the code as localhost (127.0.0.1) UDP all worked fine.
Disclaimer: I am a "user" of the IoT-kit and am not involved in the actual IoT program so I am speaking from personal experience rather than actual knowledge/training.
Chandler_H_
Hi Peter,
Thank you for the reply. I am finding that that Arduino IDE delivery of the sketch is broken. Something changed between the Gen1 and Gen2 as there are other issues I am seeing with IoTkit 1.1 too. The Galileo Gen2 console reports a segfault after upload of the sketch from Arduino IDE 1.5.3 (1.0.4).
Are you able to use the python version with the Arduino breakout board and shields? At this point I am open to other options.
Cheers,
Chandler
PeterKerney
Unfortunately I cannot comment on the Galileo issues you are facing. I am using Edison with the Arduino board and have the Python temperature update working with the code below (basically the same code from GitHub) from the shell when running the iot-agent on localhost as a daemon started from systemctld.
I have not used IoT dev kit from Arduino at all I might give that a try at some point. I am just starting to play with Python IoT and the dashboard. Not started on shields yet. I was planning on tackling mraa and SPI/I2C next in order to get my SSD1603 OLED display working.
#!/usr/bin/python
import os
import socket
import json
import time
HOST = "localhost"
PORT = 41234
INTERVAL = 60
def send_data(metric_name, value):
#    print "Sending data", metric_name, value
    msg = {
        "n": metric_name,
        "v": value
    sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    sock.sendto(json.dumps(msg), (HOST, PORT))
def get_temp():
    temp = 0.1
    temp_src = "/sys/class/thermal/thermal_zone3/temp"
    if os.path.isfile(temp_src):
        try:
            f = open(temp_src)
            t = f.read()
            temp = int(float(t)) / 1000
        except IOError:
            pass
    return temp
next_send_time = 0
while True:
    t = time.time()
    if t > next_send_time:
        temp = get_temp()
        send_data("temp", temp)
        next_send_time = t + INTERVAL
    time.sleep(1)
Rahul_S_
@ Chandler
Have you tried starting the iotkit-agent?
Use root:~# systemctl start iotkit-agent
Chandler_H_
@ Rahul,
I have started the iotkit-agent and it is running. I just never see any data passed from the arduino side to the agent and off to the dashboard.
Cheers
